Question about GE JVM2070 Microwave Oven
We have a ge Profile JVM2070WH02 microwave. The touchpad has stopped working. The Vent Light and Boost buttons work. The clock works fine. The touchpad lights up when you open the door.
5 Suggested Answers
  • 4088 Answers
SOURCE: ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Posted on Jul 16, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a
handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
Posted on May 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a GE microwave # JVM2070SK02 that the
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 22, 2010
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
GE JVM2070 Microwave Oven Logo
486 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
