Question about Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood
Bosch AQ 125 FX LP model will not light or stay lit......
Sometimes it lights correctly, but usually the fan doesn't start, piezo ignites the burner and burns until over-temp switch shuts off gas. Replaced the control unit, but I still have original problem. If the fan does start it runs fine for about 10 to 15 seconds, then shuts off. Other times nothing happens, no fan, no piezo, no ignition. I use a whole house pre-filter, don't have hard water issues and have never found any debris in intake filter. Any suggestions? I've already spent almost 40% of the original cost on parts for a 7 year old unit. It has been flawless until the last 3 weeks.
meBNme
  • 334 Answers
SOURCE: pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Posted on Dec 06, 2008
  • 25 Answers
SOURCE: bosch gwh-425ef nat gas on demand heater
Actually this sounds more like a bad ECO on the outgoing hotwater pipe. Disconnect it and ohm it out for about .5 ohms with a digital multimeter.
Posted on Jan 19, 2009
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Posted on Jun 09, 2009
  • 518 Answers
SOURCE: I have a Bosch AquaStar AQ-125-BNG tankless water
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Posted on Jul 05, 2010
SOURCE: aq 125 blp Bosch tankless water heater, pilot
Natural Gas: Pilot burner or orfice may need to be cleaned. Pg 11 manual.
http://www.boschhotwater.com/Portals/7/TechManuals/125BL_English.pdf
Most tank and tankless gas water heaters today suggest annual cleaning and maintenance of burner.
Open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BLTechSupport/Troubleshoot/tabid/474/Default.aspx
Posted on Jun 14, 2011
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Aquastar 125 blp
Most of these have a safety switch, that would make the pilot shut down. Also check for rust deposits in your fuel line, and pressure.
Aug 23, 2014 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
I have a bosch aquastar aq 125fx probably 9 to 10 years old it heats fine but after about year 2 it stopped working when you fire it up shortly or immediately after firing it up before. in other words it...
You either have a weak spark from your ignitor which needs replacing, a bad elec connection to the ignitor, or it needs to be repositioned nearer the burner. Check connections and try repositioning it before you install a new on.
Apr 30, 2017 | Bosch & Tankless LP Hot Water Heater
Bosch aq 125
Check for crossover, aka cross connection
http://waterheatertimer.org/Crossover.html
Install ordinary tank electric water heater for $250 and solve problem quick, sure and cheap
Jun 06, 2013 | Water Heaters
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
5yr. old aquastar 125x lp wont stay lit after about 5min. use. just started happening out of the blue... a clicking noise preceeds the flame shutting off. any ideas?
The gas valve makes a single click sound when the pilostat shuts off. That is a safety holding coil for units with standing pilot lights and closes if it thinks the pilot went out. In electronic ignition, the same holds true except the sensor is electronic.
Mar 31, 2011 | Bosch & Tankless LP Hot Water Heater
Our Bosch model AQ 125 Bong water heater pilot light will not stay on. We've tried numerous times. The instruction suggest a service technician. There are none available in our area. What the best...
It sounds to me like your thermocouple is bad . See if you can trace it from the gas valve to pilot light. Remove thermocouple and try to get a exact replacement part. If the length varies don't worry about that. Install new thermocouple and see if that doesn't solve your problem. Thanks
Dec 01, 2010 | Bosch & Tankless Water Heater
Bosch AquaStar 125FXKIT-LP 125FX Liquid Propane Gas Tankless Water Heater w/ Hood Logo
510 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
