Question about Braun Syncro 7505 Electric Shaver
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
Posted on Jan 11, 2013
4 Suggested Answers
SOURCE: switch is stuck in on position braun 7505
Pry out the blue button. In the oval hole where the button was you will see a thin metallic part (semi-circular shapes on each side); pull it out through the hole and the switch will be functional.
Posted on Aug 12, 2008
brector3
  • 1600 Answers
SOURCE: Braun shaver 7505 trimming blade slide will only
The trimmer and on/off switch are part of the same mechanism. The problem is that the switch apparatus is broken and preventing the trimmer from sliding up. You can't repair it without replacing it.
This is a hard part to find for your model and I don't know where to direct you to purchase one.
I have another suggestion which will be a good remedy especially if your shaver has original batteries and is over 3 or 4 years old. This suggestion is to replace the whole 'lower unit'. This would be the entire handle portion of the shaver. You can upgrade to a nicer model at the same time. Take a look at this compatible lower unit at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7680-syncro-lower-unit-p-642.html
Posted on Feb 14, 2010
brector3
  • 1600 Answers
SOURCE: Batteries run down faster (Braun 7505)
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Posted on Jul 15, 2010
I need a new battery for this razor. I know its replaceable, but where dose it go and how do you get the cover off?
You will find the correct battery type for model 7505 at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
You will need two batteries. Scroll down the item page for videos showing disassembly and installation tips
Jun 21, 2011 | Braun Syncro 7505 Electric Shaver
Jul 14, 2010 | Braun 7000 Series Foil and Cutterblock
Braun shaver 7505 trimming blade slide will only move between position 3 (trimming) part way to 2. It will not go to 2 or 1(off). This happened suddenly. Shaver operates with cord, but must be unplugged to...
Feb 13, 2010 | Braun Health & Beauty
Shaver not charging.
The batteries should not really get warm. You may not have a good solder connection
Assuming that the batteries are in correctly with good solder joints, the problem is likely the motor. With the shaver fully assembled, remove just the foil and cutter and then turn the unit on. Use your finger to push the piece of plastic that the cutter fits into back and forth. If it starts and moves slowly or if it stutters, the brushes in the moto are probably bad. Because the motor is a sealer unit, the motor will need replaced. If you require this part, you will find it at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jan 31, 2010 | Braun Syncro 7505 Electric Shaver
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
Braun shaver 7505.
Greetings,
Need to replace the switch. If you have the skills to disassemble the unit, proceed. Otherwise replacing the shaver will cost you less than having it repaired.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 01, 2008 | Health & Beauty
Braun Syncro 7505 Electric Shaver Logo
972 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
