Question about GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS
GE French door profile freezer is not freezing
Our GE French door profile model " pfs22sisbss " had beed running high between 9 - 25 last weekend. We scheduled a service call for the past Friday. By Friday morning it turned down to 1 . The service guy looked at it and said the board needed to be changed. He changed it on Friday, yesterday morning and it has gone up to 32 since then.
The fridge is 2 years old! Please do you have any suggestion?
Thank you for your help.
    Top Expert:
  • GE Master
  • 83,850 Answers
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Posted on Jul 03, 2017
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
  • 74 Answers
SOURCE: I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Posted on Feb 26, 2009
shastalaker7
  • 1515 Answers
SOURCE: I have a 10 year old GE Profile refrigerator
Hi, It sounds as though the condenser coil may have a sheet of lint on the front of it causing the compressor and system to have higher then normal head and suction pressures. If you can pull it out to get behind it, there should be a fiber panel on the bottom. Remove it. You will see a small fan motor, a coil, and the compressor. It sounds that if the compressor runs all the time and its not as cold as before, this coil needs to be cleaned. If the fan motor is not on but the compressor is, the condenser fan motor is faulty. If it is on, try and clean the front of this coil very good. Shine a light through it also. If you pull a sheet of lint from the front of it, this was your problem. Do this, and keep me posted on the unit in case this is not the problem. Thank you,
Shastalaker7
Posted on Feb 16, 2010
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile french door refrig not cooling but freezer is cold
Look into rear of freezer and see if a layer of frost is building on rear panel. If yes you will need unplug and manually defrost with a hair dryer. That will help speed things up. You will also need the correct model number to get the correct parts. The odds are the defrost heater is defective. Because cold air is heavier than warm it tends to settle to bottom freezer making it appear OK. If there is no frost in freezer rear wall then we would look for the air supply damper to be closed between compartments. Look and see what you are going to need do and I will look up the parts assuming your model is a PFSF5NJXBB I will return soon, Thanks, Sea Breeze
Posted on May 16, 2010
I have a PFS22SISBSS ge profile refrigerator bottom freezer the bottom freezer tray fell to the ground since the plastic bar that holds it onto the metal track has cracked and broken in half on the right...
Not unusual.
Contact them and tell them they got it wrong and you are sending it back at their expense.
Ideally they should email drawings and a parts list on demand so you can quote the correct part number but if they refuse produce a line drawing of the part you need and include a couple of photos...
Feb 05, 2018 | GE PFS22SISSS Stainless Steel French Door...
My ge profile PFS22SISBSS FRIDE IS NOT STAYING COOL WHAT COULD BE THE PROBLEM?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
ICE MAKER NOT WORKING ON GE PFS22SISBSS
Lets try this first. Unplug and then wait 10 minutes and then replug. That should reset the memory for the motherboard. If that does not work contact me asap, Sea Breeze
Mar 13, 2010 | GE Profile PFS22SBSS Bottom Freezer French...
GE Profile PFSF5NJW French door Bottom freezer. Freezer is fine. Refrigerator at 60 degrees. Unplugged for two days to thaw any possible freeze up. Refrige still at 60 degrees.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Nov 21, 2009 | GE Profile PFSF5NFW Bottom Freezer French...
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS Logo
180 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
