Question about Sony KP-57WS500 57" Rear Projection Television
I have volume but no picture... - Sony KP-57WS500 57" Rear Projection Television
No picture on my flat screen but I have volume
Is there back light or is there a picture if you shine a flashlight at the screen, looking at an angle?
Aug 26, 2014 | Hisense Televison & Video
Tv has no volume or picture but turns on
replace the mainboard and power supply.
Jan 21, 2013 | Televison & Video
Picture went out on flat screen volume is fine
sounds like your vertical circuit was going bad then might have overheated and killed the power supply. a repair cost might range around $300.00
Good luck...
Jun 01, 2010 | Televison & Video
No Picture or sound in TV Mode
Are the RCA cables matching(in tv to out sources.audio to audio and video to video)?And make sure the cables are in working condition
Nov 15, 2017 | Sceptre Naga III X27SV 27 in. HD-Ready LCD...
I don't know how to use the pip button, i know it means picture in picture and it's like a double screen but how do you change the channel or volume on each side of the screen?
You can only hear the audio from one picture at a time. You can change the volume the same way you would normally change the volume. Let me know if you have any further questions.
Nov 20, 2009 | Hitachi CLU-4324UG Remote Control
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
sorry dry solder joints this model was a disaster for this not worth repairing
Oct 12, 2007 | Toshiba 32A35 32" TV
Sony KP-57WS500 57" Rear Projection Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
