Question about LG Dryers
LG TROMM DLE7177RM Dryer: when I turn power on it says Clean Filter, filter is clean. when I select settings and turn dryer on it says simultaneously ''DRY'' flashing and ''COOLING'' on -- it ends up taking about 3 hours to dry a load. I've read the manual but can't find anywhere what this could be. I have unplugged the dryer for 30 minutes to reset the control board; however, this had no affect. I have unhooked the vent from the wall to see if there is good air flow, and there does appear to be adequate ventilation. Any help would be appreciated.
  • 760 Answers
Ah you unhooked it from the wall, but did you go outside and see if air flow was adequate outside. Quite often flexable hoses and duct work get plugged with lint. If that is the case be glad your dryer had pleanty of safetys. If you start it briefly with the hose disconnected, do you get the dry light flashings? Metal duct work all the way outside is best.
Posted on Jul 11, 2010
Testimonial: "That was the issue, I had a 25 ft metal duct and it did need cleaning. Thanks"
How to clean the pump filter on an LG tromm
Do you have the manual for the washing machine. This is documented in the manual.
Sep 01, 2014 | LG Tromm Front Load Washer And Dryer Set
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
LG Tromm DLE8377NM check filter but filter is clean
You say lint hose is disconnected. Are you referring to the exhaust vent to the outside? I would suspect this vent is clogged or a vent flapper outside may be stuck shut.
Feb 14, 2012 | LG Dryers
I have a lg tromm dle2514 dryer and the check filter light is on. I am willing to clean it (I've already cleaned the front filter area) I just have no idea where there is another filter
There is no other filter to clean other then the one lint filter.
I would check the dryer vent to make sure it's not restricted with lint build up or has any kinks in it. Also check the outside flapper at the end of the dryer vent to make sure it's clear of lint and able to open all the way.
If your dryer vent is ok and the lint screen is clean then I would remove the front of the dryer and check the blower/fan housing for lint build up.
Aug 04, 2011 | Dryers
LGDLE0442W Dryer check filter light on. Flter clean dryer sounds like it wants to start but doesn't. Is there a reset button?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | LG DLE2514 Electric Dryer
LG Tromm dryer says clean filter and won't run. Filter is clean.
CHECK YOUR HOUSE VENTING. MANNY TIMES IF THE EXAUST AIR IS NOT GOING OUTSIDE FAST ENOUGH IT WILL GIVE YOU THE SAME ERROR.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 15, 2010 | LG Dryers
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
Everytime i turn on my lg tromm it says check filter
TRY TAKING OFF THE VENT HOSE AND RUN A CYCLE WITHOUT IT AND SEE IF IT DRYS FASTER....YOU MAY HAVE A CLOG OF SOME SORT IN YOUR WALL
Jun 23, 2009 | LG DLG5988 Gas Dryer
Dryers Logo
869 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
