Question about Euro-Pro F1061 Deep Fryer
Fryer will not turn on
My fryer will not turn on after the first use.
  • wrenmurphy Feb 22, 2009
    I have same problem. I see red reset button. When I push on it, nothing happens. How to make it reset?
There's a red reset button that you need to press, it is hidden deep inside a well in the plastic piece. The well looks just like a screw hole until you know what to look for. Once you press it and your power supply is attched right you are golden.
Posted on Jun 26, 2008
Remove the oil and the gunk from the bottom. Put everything back together,(make sure you align the slots there is a trigger). Here's the kicker!!!!!!!! Heat some oil up in a seperate pan, then pure the hot oil over the thermostat,(the prope in the bottom). This will clean all the old oil off.That's what is causing the malfunction. The old oil has sufficated the probe.Worked for me.Good Luck!!!!!!!!!!!!
Posted on Mar 05, 2009
Why won't it turn on?
How to fry a Turkey - Butterball Indoor Electric Turkey Fryer ...
? 8:18
https://www.youtube.com/watch?v=PsAm5jGkOck
Nov 11, 2013 - Uploaded by therealcobraburnout
Butterball Indoor turkey fryer set up and first use. ... In case anyone trips on the cord, the whole fryer won't get knocked over..... well it holds 20lb bird, so you might be able to do maybe to smaller 7lb ones .... Just remember the oil will turn rancid in about 6 months once opened depending on how you store it ...
Butterball Indoor Electric Turkey Fryer - YouTube
? 2:35
https://www.youtube.com/watch?v=LJc8gf2QlG8
Nov 7, 2010 - Uploaded by tulwave
For More On Butterball Indoor Electric Turkey Fryer visit: ... Buy one and try it and i bet you won't be so negative. This thing works great for all ... I usually calculate 3
Dec 25, 2015 | Masterbuilt Butterball Electric 20 lb....
I have a star deep fryer that over heats the oil and then trips the breaker on the back of the fryer.
Has to be a stuck thermostat or a bent or broken bulb, tube in the fryer oil. When replacing the control be careful not to bend the tube to much to pinch it closed. This is a very small pipe. Check by turning the thermostat from low to high and see if it will turn off the fryer. It could be out of calibration but unlikly when the high limit kicks off.
Oct 08, 2014 | Star Max Electric Counter Fryer 301-HLD
On the display appear a sign of "draining " and the fryer does not satr
Are all drain valves closed completely? Will not turn on if there is one open...
Jan 02, 2014 | Vulcan 1GR45D Fryer
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
We purchased new fryers that are Imperial IFS40 and the salesman was going to check them out and demonstrate the fryers by putting water in them and turning them all the way up. It got so that the water...
Fryers use 2 types of stainless steel. Get a magnet and see if it sticks to the inside of the tank. If so...that is a lower grade of stainless. Use some steel wool to clean the rust spots and cover with vegetable oil. The tanks should be ok if you just bought them.
Tom
Jun 22, 2010 | Imperial IFS40 Deep Fryer
Fryer coming on without turning thermostat on
Imperial Model: IFS-40.
The thermostat is either very far out of calibration or has failed, either case it should be relplaced. The Imperial Part # for the thermostat is 1175.
May 04, 2009 | Imperial IFS40 Deep Fryer
Flame will not turn off
Your t'stat switch is bad. Will it turn off on hi limit?
Feb 10, 2009 | Pitco Frialator 35C Deep Fryer
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Euro-Pro F1061 Deep Fryer Logo
759 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gerry Harvey
Gerry Harvey
Clarice Bornschein
Level 1 Expert
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
