Question about Hampton Bay Heating & Cooling
Hampton Bay window AC unit not blowing cold
Hi. I have a Hampton Bay window AC unit (model HBLG 1004R) that all of a sudden is not blowing cold. Any idea of what to do....maintenance required, freon added, etc.? I have already cleaned out the filters but no avail.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Recharge My AC Unit
The system needs to be accessed through what is call a tap valve. After a tap valve is in place a high vacuum should be pulled on the system down to 500 microns to remove air and non condensible gases along with any moisture from the system. Then the charge should be weight into the system according to the name plate with the proper type of refrigerant, generally Refrigerant 22. An alternate method is to charge the system by superheat of the gas returning to the compressor. Ambient temperature determines how high or low the superheat should be.
Posted on Jun 20, 2008
SOURCE: Owner's manual for a Hampton Bay HBTE120 Air Conditioner?
http://www.appliancefactoryparts.com/content/pdfs/118255.pdf
this is the pdf of the manual for that particular model of a/c.
hope that helps.
Posted on Aug 29, 2008
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
soroka69
  • 3 Answers
SOURCE: I have a model HBT120A Hampton Bay window unit
This unit is 12,000BTU, in production since 2001
For parts go to :
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=115770
Posted on Aug 19, 2009
I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
JP
Jun 21, 2015 | Hampton Bay Heating & Cooling
I have a Hampton Bay air conditioner model # HBLG 1800H. The unit is about 4 years old now. Here lately when I turn the unit on low cool it starts cooling the room and then the compressor shuts off which I...
Sounds like a bad thermal overload which opens when the compresssor gets too hot. After the compressor cools down it closes and does not re-open unyil the compressor gets hot again. Check your wiring diagram if you have one and look for a symbol like two question marks on top of one another or the letters O/L. That seems to be what is occurring here.
If this helps you please rate me on fixya.com
Aug 03, 2011 | Hampton Bay Heating & Cooling
Water is not draining out the back of the window unit and water is blowing out the front and fan is making a noise
Kathy, there are 2 reasons this happens.
1. the unit is not tilted down at least 1/4" on the outside of the window.
2. The drain hole in the condensation pan (under the unit) is clogged.
Resolving the above (either one or both) should solve the problem.
In the meantime turn the AC unit OFF.
Hope this helped you.
Jun 23, 2011 | Hampton Bay HBLG5004 Air Conditioner
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Coil freezes up. is there away to recharge window unit. The unit is heat and ac the unit is a hampton bay Is there a manual that can be down loaded?
Check your filters first and make sure the fan is running. These will cause it to freeze up also. A window unit can be recharged, but depending on what has to be done it can cost as much as a new unit. Check around for prices on service calls.
May 10, 2010 | Hampton Bay Heating & Cooling
Hampton Bay Stopped Suddenly while running
The motor may just need a good blowing out. If you can remove the fans motor and use compressed ait it can be cleaned thoroughly. First tun the motor by hand to see if it spins freely. It may have a dried up bearing locking up the fans shaft to the motor causing it to have stop. YThe bearings have a flat colored seal which can be popped off to relube then snap the seal back in
Apr 10, 2010 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Jul 16, 2009 | Hampton Bay Heating & Cooling
BTU
There should be a tag somewhere on it. Take the front grill off and look in the area where the fan blows out the grill face or below the evap coil face where your filter covers the coil
May 14, 2008 | Hampton Bay Heating & Cooling
Heating & Cooling Logo
489 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
AJMAL KHAN
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
