Question about Samsung AW1203B Air Conditioner
I just moved and my air conditioner dosent fit in any of my new windows because there to small and I'm hoping there is an easy way that I can just put it in my house and have it still work?
The power on my N120E - DeLonghi 12,000 BTU Portable Air turns itself off
The DeLonghi Pinguino Air Conditioner is such a smart choice for people in need of a little extra cooling in their homes! My better half purchased our a couple of years ago when he realized his office was getting much warmer in the Summer than the rest of the house. Being hot natured, he thought a portable air conditioner would be a smart choice. We've loved it! It's on wheels, so you can move it from room to room quite easily (even my 10-year-old has been known to move it.) It's outside vents attach to an adjucstable plate that fits right in any size window in seconds. Just select what temp you want it and... done! Super easy.Right now we're currently using it instead of our central unit while the temps aren't too very high.
Jul 28, 2012 | Intertherm Heating & Cooling
RE Portable AC units What are the dimensions of the window kit ? Thanks, Norm
Norm - The window kit is about 7.5 in. 'high', by up to almost 50 in. 'wide'. Minimum width as small as you like, if you can cut through plastic. Exhaust hose is 6 in. diameter. Any sliding window should be fine. However, you can customize it as necessary, to fit just about any type window.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool ACP092PR Air Conditioner
Ac comp comes on but dosent get cold
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 23, 2011 | LG Electronic Window Air Conditioner
My sons new air conditioner drips a great deal of water from the unit. He lives on the third floor in a New York city apartment and has received numerous complaints. His old Goldstar air conditioner did...
newer AC's do drip more condensate than old ones due to increased efficiency
this will help with the complaints;;; ducttape a small funnel to the outside location of the AC (usually at the tray end) where the unit drips; (you may have to cut the funnel a bit to fit) attach a small hose to the bottom of the funnel and, place the other end of the hose into a bottle inside the window on the apartment's floor; empty the bottle regularly.
Jul 18, 2010 | Heating & Cooling
Temp setting way off kenmore 580
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
May 27, 2010 | Kenmore Single Room Air Conditioner
New unit air seems not to be cold
MAKE SURE ENERGY SAVER IS ON SO FAN SHUTS OFF WITH COMPRESSOR. AND MAKE SURE THERMOSTAT IS SET TO COLDEST SETTING FIRST. IF THAT DOSENT DO IT YOU MAY HAVE ANOTHER PROBLEM.
Apr 23, 2010 | LG Electronic Window Air Conditioner
Air Conditioner just stopped working
verify that the fan is free to spin and not binded, window units are bad for this due to close tolerances in the small cases
Aug 10, 2009 | LG Electronic Window Air Conditioner
I moved and only window in living room is to small
NO! would not drain correctly for starters - would leak H2O everywhere.
May 30, 2009 | Goldstar WG5200ER Air Conditioner
Roof top rv air conditioner installation
Waeco manufacture a rooftop A/C with a matching inverter.you will need to ensure that you have enough battery power when staionary but your al;ternator will provide power when mobile you could also use a small generator through a battery charger to keep your batteriesd charged up but this is not neccessary unless you are stopped for a long period of time.these units are fairly easy to install and come with fitting instructions for the A/C and wiring kits for the inverter..hope this helps
Jan 11, 2009 | Dometic Rooftop RV Air Conditioner
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Samsung AW1203B Air Conditioner Logo
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
