Question about Kenwood KAC-9152D Car Audio Amplifier
Kac - 929 kenwood 1000 watt amp
My subs turn on, turn off, turn on, turn off, while driving. The power is on, but it cuts out randomly. Any advice?
  • john wasson
    john wasson May 11, 2010
    hmm is it cutting off? or is the audio just cutting out?
    Novelist:
  • 77 Answers
Does it do it when car is not moving? If it does'nt then it is a bad connection in the amp itself or outside the amp. Check all your external connection well, it is easy to pass a bad connection up without knowing it. I recomend checking every connection, redoing the connections. Then you can rule that out and may find the problem. If connections don't fix problem let me know i'll be glad to help. I have my own amp repair business and people send me there amps from all over the U.S. Just send me a message and
I'll take you thru some steps to diagnose the amp if problem persists after connection checks. Good luck, hope to hear from you!
Posted on Aug 02, 2009
    Genius:
  • Kenwood Master
  • 1,689 Answers
Cold solder or lose connection in the amplfiier, or a poor connection with the wiring. The vibration of the movement of the car is causing the intermittants.
Jerry G.
Posted on May 01, 2008
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I have one 10in. Kicker L7. and a Kenwood KAC-929 1000 watt amp. What are all the wires i should buy that can make this setup run?
Need an amp kit up to 1000 watts, speaker wire. Amp kits have most of the wires needed such as, power, ground, and remote wire. As well as all the connectors needed.
Sep 22, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
Can you power 2-10" subs and 2-6x9 speakers with this amp?
You could but the only problem is even if you ran the speakers in parallel, meaning + to + and - to -, the best power you would get out of the amp is 230 watts per channel. Would probably make your 6x9 sound good but not enough to push your 10's.
Nov 19, 2009 | Kenwood KAC-929 Car Audio Amplifier
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-929
From the Input of amp, just connect cheap speaker with wires to input of amp.
If you have sound from speaker, most likely the amp is bad or loose connection.
Dec 25, 2007 | Kenwood KAC-929 Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
793 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
