Question about Soleus Heating & Cooling
When compressor shuts off unit blows warm air
  • Soleus Master
  • 43,501 Answers
I think that you could expect the air to be warm when the compressor is not running...
heatman101
Posted on Jul 12, 2010
PTAC UNIT BLOWING HOT AIR IN COOLING MODE
Hot or warm? Sound like float switch shuts compressor off. Vacuum the drain and clean the pan
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 24, 2016 | Heating & Cooling
Why is it blowing warm air?
U say the compressor fan is running. How about the compressor - is that running? Without the latter running there is no way you will ever get cold air!
Check for bad start cap/start relay.
Sep 21, 2015 | Heating & Cooling
Air cinditioning wont stay on, it switches to heat and wont shut off
What do you mean when you say it wont shut off? is it blowing hot air or do you just feel a lite flow of hot air even if you have the settings to cold?
If this is the problem that you always feel hot air at low flow and the ac goes to hot air then i would say one of two things, first if you have the selector to cold and you feel hot air then there may be a problem with the blend door, this door move to allow hot or cold air, the door may be broken or just a bad motor that controls it. keep in mind if the ac system shuts down for any reason the air then will be warm, it will be about the same temp as outside and maybe a little hotter.
this problem almost sounds like the ac compressor shuts off and then you are getting the outside air which is hot, there are many reasons for the compressor to shut off, it could be the compressor clutch heating up and disengaging , this would be due to a bad compressor clutch.
another reason is the fans are not working, the best thing to do is when the system starts to blow warm check and see if the compressor is running, start engine and look at the front of compressor, with ac off the front of it will not move, and then with ac on the front will spin, check it out and let me know, if it blows warm air and ac is not working then it may be compressor problem but if you are getting warm air and the compressor is spinning then it may be a door problem.
This is hard to check with out testing the system, so i listed a few things to check and let me know the out come. also the ac blows cold for how long before it gets hot air blowing out of the vents, good day.
May 25, 2012 | 2000 Dodge Grand Caravan
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
When compressor on the blower keeps trying to shut down.
You may have a bad capacitor. But you may nee a service tech to check it out. There is only so far you can go without knowledge of Air Conditioning. Ask for free estimate and you will know upfront what the cost is . RUS
Jul 15, 2009 | Heating & Cooling
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Heating & Cooling Logo
327 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
