Question about Targus Chill Mat PA248U Laptop Cooler
Cooling fan not turning on
I just purchased this cooling mat and plugged it into my computer through the usb drive but it won't turn on. Both sides are in fully, but not even a breath of air.
    Brigadier General:
  • 4,044 Answers
There is a problem with the power supply cable that I have found in several of these. The wires break or short at the plug. You can purchase a replacement Multi-volt power supply from Walmart, set it for no more than 5 volts and plug it into the fan. It will work. I actually have mine set at 1.5 volts. Another problem with this could be that the USB port you are using is not coming on or has shorted out. Test the port with a thumb drive to make sure it still works. If it does then use the external power supply.
Posted on Jul 11, 2010
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
My lap top gets too hot and shuts down
1. blow into the intake vents with canned-air
2. obtain a 'cooling-pad' for a laptop your size
example of a mat-style cooling pad
Xcellon ChillPad Laptop Cooling Mat Gray Black
example of a fan-style cooling pad
Generic Mini Fan USB Cooler Cooling Pad 2 Fans For Laptop Notebook PC...
Oct 28, 2014 | E-Machines Computers & Internet
The cooling fans won't turn on..
Did you try your radiator fan relay ? if thats not it i would try the coolant temp switch for the engine control computer . lastly if those dont solve the problem you have ecu issues or the cooling fan module.
Dec 05, 2012 | 2001 Dodge Stratus
Acer laptop comes on then turns off
Sounds like the CPU is overheating. That's about how long it takes if there is no cooling to it. Check the air inlet and exhaust openings on the sides of the laptop. Listen for the fan(s) when you turn it in. If the ports are clogged, or the fans are not operating, this is a good reason for your problem. Many people will try to use a laptop laying on a bed or sofa. This can cause blockage of air intake and result i overheating and overworking the fans causing premature failure. A computer repair center can replace fans, or you can get a good quality external cooling mat to aid you.
Jan 13, 2012 | Acer Computers & Internet
I got a Targus PA248U Notebook Chill Pad, the part inside where I plug the cable in is messed up I think and it won't power on. How do I open it up to have a look to see if I can fix it?
I opened the case and hard wired the power cord directly to the wires of the fans. There are 4 philips-head screws at the four top corners under the rubber adhesive pads. Separate the top from the bottom. Two wires come from each of the fans. Cut and twist the two positive wires together and the two negative wires together. Cut the end off the power cord that is NOT the USB end and strip the wire insulation back. You will find a white insulated wire surrounded by another wire. Twist the ends of each separately making sure they are separated by the white insulation. Remove the circuit board using the tiny screws where the switch is and put the power cord end through the switch hole. Tie a knot in the cord to prevent cord from pulling out. Make sure the USB end can reach a USB port on your computer. Carefully test which wires to twist together by touching each to see if the fans turn. One way will work and other way won't. When sure of correct wires, you can solder them together and insulate properly with small wire nuts or electrical tape. Reassemble case with screws and plug in USB cord end when you want the fans to cool your notebook computer. I hope that this helps.
Jan 20, 2011 | Targus Chill Mat PA248U Laptop Cooler
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
I.ve changed my motherboard and no longer have a 3 pin connection for the case fan on the motherboard. I know that + goes to yellow and - goes to black but where does the sensor wire go?
Hi:
An option for you is to just purchase a cheap adapter to plug your case fan into a unused power supply plug, such as one that plugs into a hard drive or optical drive.
Dec 11, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Replaced cooling fan relays,the cooling fan
check temp sencer wire at bottom of raditor
Jun 04, 2009 | 1989 Buick Regal
Computers & Internet Logo
702 people viewed this question
Top Targus Computers & Internet Experts
J John
Dudeman321
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
