Question about Sony Cameras
Cannot download pics to computer...power does not turn on when connected to compuer
  • kakima Jul 11, 2010
    Hae you considered NOT connecting the camera to the computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
  • Sony Master
  • 17,130 Answers
Yes,as mentioned the best way to download is to remove the SD card and insert it to the card reader in your PC or laptop. If you do not have this facility you can get a card reader interface to be connected. this is quicker and will not need the camera to be installed and the connecting cord to be fixed to the PC.
The SD card will be detected and you can save to a marked folder.
Posted on Oct 18, 2011
The compuer is not connected
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Me screen keeps black allthough the computer is on
Try doing a power drain.
1. Turn computer off by pressing the power button for about 5 seconds.
2. Take the battery out.
3. Unplug the ac adapter.
4. Press and hold the power button for about 15 seconds.
5. Put everything back in.
6. Turn the compuer back on.
there goes your display back. Thank you for visiting FixYa!
Apr 23, 2011 | Lenovo 3000 N200 Intel Pentium Dual Core...
My camera comfortably copies' internal memory' pictures to the compuer, but can not copy any files on the 'memory stick duo' to the same destination.I only keep on receiving a small pop-up with a message...
Most people find that if they use the internal memory of their camera, they have problems with the memory card. The solution is to erase the internal memory and vow never to use it again. Here's what you need to do now. 1. Download any pics from the internal memory you want to save. Then, with no card in the camera, go into the menu and find "format"(may be called "initialize") and follow the on-screen instructions to erase the internal memory. 2.Download any pics from the memory card. Use a separate card reader if necessary. (You'll find that using a card reader is the best way to download). 3. With the card in the camera and your pics safely downloaded to your computer, do the "format"/"initialize" thing again, this time to the card. Now, everything should work perfectly. typrice_28.jpg
Nov 16, 2010 | Cameras
Never got a manual for samsung s860 digital camera
i cant upload photos in my computer as my camera when connected to the computer is showing CONNECTING COMPUER , then making 3 buzzing sounds and getting switched off instantly.
Nov 25, 2009 | Samsung S860 Digital Camera
Camera wont turn on after trying to download pics to computer/can't find pics on computer now
You probably had a bad USB connection that supllied to much voltage (or had a bad ground or reverse polarity) to the camera and shorted out the circuit board. Disconnect all cables. Hook up to a charger and try again. If this does not work, the camera is fried, sorry.
May 07, 2009 | Kodak EasyShare V1003 Digital Camera
No display, screen is blank even compuer is running
Can I assume (?) you re-tried firmly checking each cable connection and the power supply is soundly in place including checking the fuse in the plug That's all I can suggest as the things I would do if in your shoes.
Aug 05, 2017 | BenQ FP72G (Black, Silver) 17 inch LCD...
I DELETED THE DATA FILE ON MY MP3 PLAYER
this is a simplest problem  generally in mp3 player
so just format your device by going to my computer
and right click on it
and format it now
or my compuer> right click> format then restar your computer
NOTE:  UNPLUG THE DEVICE
Oct 01, 2008 | MyMusix PD-6070 MP3 Player
Cannot download my pics
"I have tried to upgrade but to no avail." i need more info about what happens when you connect your camera but incase you haven't tried, the camera must be turned on after you connect it via usb. vista shouldn't be a problem. does the scanner and camera wizard launch when you connect your camera? i'm not too familiar with olympus models, but try connecting the [powered down] camera to your computer while it's in PLAY mode. power it up and see if windows will launch a prompt. is your computer new? many newer models have card readers built right in. if yours does not, and the above suggestions didn't work, try connecting an external card reader and uploading your images that way.
Apr 10, 2007 | Olympus C-3000 Zoom Digital Camera
Cameras Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
