Question about Gateway FPD1975 19" LCD Monitor
Gateway monitor 22"
My monitor has a wateway shield anti-theft and is in color for few minutes and the goes on black and white I remove the shield program from the computer like I was told by gateway. It work for few weeks but now is back in black and white. I lost the pin# and do not know what to do.
I think the guys at www.securedata.biz have a fix for that.
Posted on Jul 11, 2010
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY IIIĀ® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
Mar 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Monitor powers on then goes black after a few minutes. Turn the monitor off and on again it resumes working for a few minutes then same problem.
Check to make sure that a CCFL has not burn out. If this is not the case you will have to repair the Power Inverter unit. Be very careful as these Caps can store LETHAL Voltages. TCC
Jan 29, 2011 | KDS 2237MDWB 22" Monitor
Gateway EzeTune
Exact same thing happened to me and gateway technical support are clueless. Try this fix:
Unplug the power at the back
wait 1 minute
hold down the power button and at the same time plug back in the power cord at the back
keep the power button pressed for 15 seconds.
Jan 12, 2010 | Gateway 19" Widescreen Flat Panel TFT LCD...
Connection?
check the videocard. remove it and place it again if no improvement try to connect monitor to another system. If no color, replace monitor.
Nov 03, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway sheild theft mode display and everythings blk+white
The problem was repaired by, Calling gateway. You pull up the challange code #'s on the monitor. You tell gateway agent the code numbers, they tell you a unlock code. You enter that on your monitor. and thats that! You pull up the challange code by unpluging your monitor then hold the menu button on monitor. plug back in holding the menu button! larrygl.
Jan 26, 2009 | Hyundai L90D+ 19" LCD Monitor
Theft Deterrance system
If you ever have this problem but cannot get to the 'extras' button, leave the computer on that (hopefully) already has the eztune software installed, pull the power on the monitor (the cord, not just press the power button) and then plug it back it...it should unlock automatically. It ticks me off that I just got off the phone with gateway tech support and they wouldnt tell me that because my monitor is 'out of warranty'...purchased 4/8/08 and problem today 7/15/09...bums. Anyway, they offered to fix for a fee. I got it fixed.
Sep 29, 2008 | Gateway FPD1975W 19" LCD Monitor
EzTune problem with lost PIN number to disable Theft Deterence
Whatever you do - DON'T CONTACT GATEWAY. I am in the UK, and the Gateway support number is only available 9 - 5 (funny 'cos I'm at work then and can't access my PC), so I filled in the technical support form - waited 2 days for a reply only to be told they don't support third party software.
I had an online chat with US Gateway support - only to be told the same thing - alternatively, pay them silly amounts of money and phone the US and they will fix the problem.
The solution is to visit Portrait Displays (software developers) website and complete an online form with your problem. (This form prompts as to whether you have already contacted Gateway - so maybe they are monitoring the adequacy of Gateway support. The support from Portrait has been brilliant.
Unplug the cable from your monitor and then hold the power button while you plug the cable back in. When the monitor is fully restored,
release the power button and an anti-theft box will appear, prompting you to press the menu button at the side of your monitor. Press the menu button and you will be given a 3-digit code. Portrait need this code to give you an unlock code. Once you have the unlock code you can remove the anti-theft option.
Feb 29, 2008 | Gateway FPD1975 19" LCD Monitor
Samtron vga cabal color coding problum
SIGNAL CABLE WIREING.
1) RED
2)GREEN
3)BLUE
4)GROUND
5)BLACK SHIELD
6)BLACK SHIELD
7)BLACK SHIELD
8)BLACK SHIELD
9)BLACK
10)VILET
11)
12)ORANGE
13)SHIELD
14)YELOW
15)WHITE
Jan 23, 2008 | SAMTRON 55V 15" CRT Monitor
Gateway FPD1975 19" LCD Monitor Logo
260 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
