Question about HP Workstation Xw4100 PC Desktop
I have a xw4100, I need to change the motherboard, do you have a recomendation?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
I just changed my board got it on Ebay you can find lots of parts for workstation there .nice to have the OEM board all the plugs are perfect. One thing back up all your docs I had to re-install 7 ultimate with thie new board for the drivers
Posted on Nov 12, 2012
    Champion:
  • 218 Answers
Yes the asus 775 motherboard good board
Posted on Jul 12, 2010
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
How do i connect my hp deskjet f380 to my hp workstation xw4100
Did you load the printer drivers? Simply connecting a printer to the machine will not get it to operate. Each printer comes with software that must be installed to get the printer to work the computer. If you need drivers, you can go to the HP website support and download them.
Jan 01, 2012 | HP Refurbished workstation xw4100 (DH9745)...
I have an hp d530 cmt motherboard with tray & would know if it would fit in an hp xw4100 case. I have not been able to locate a d530 case.
Most mother boards are loosely speaking "one size fits all". The newer the board the smaller generally. You will have to offer it up and see. It may mean you have to move a couple of pillars.
So long as the PSU leads fit, it sholud be OK.
Dec 15, 2010 | HP Compaq d530 CMT PC Desktop
I have a HP workstation xw4100 2.8GHz. i cant find a network adaptor, under device manager it says ethernet controller and says no driver found
You can download the driver from the link below. The driver is for windows XP operating system. Incase you are using Linux or other operating system ,select the operating system first before downloading.
Link to Download
Thanks for using Fixya
Proton
Oct 13, 2010 | HP Workstation Xw4100 PC Desktop
Hi, I am having a HP workstation XW4100 Base unit previously i was using Linux on this machine now want to change the OS has Windows XP with SP2
You need a Windows XP installation disk and the product installation code.
When you boot up with the Windows installation CD, you will be given an option to delete the existing partition, Do this and then create a new partition, then do a NTSF format NOT a quick NTSF format then complete the installation.
After you install SP2 then install SP3, this is the latest service pack and corrects some bugs.
Sep 02, 2010 | HP Workstation Xw4100 PC Desktop
I have hp workstation xw4100 changed battery then the system. system not booting
If as I suspect you changed the CMOS battery, then you will have to set up the system BIOS again to the "Default" configuration. You will have to initialize the Hard Drive, DVD, RAM, Boot Up sequence, all again. Do this and all should be OK. You access the CMOS usually by pressing DEL, or F10, at boot time. Check your manual for exact key.
Jan 28, 2010 | HP Workstation Xw4100 PC Desktop
Want to upgrade my video card
Yes, your FX1100 will work, according to HP. Please refer to this link http://h18000.www1.hp.com/products/quickspecs/11604_na/11604_na.HTML
for additional cards that are supported by your system.
Oct 16, 2009 | HP Workstation Xw4100 PC Desktop
I have a HP xw4100 that will not power up. The LED will flash 4 times, I thought it was the power supply so I changed it. Did not fix the problem. thanks in advance..
You may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find.
Mar 18, 2009 | HP Workstation Xw4100 PC Desktop
Unable to get HP-D2808F3P PSU of workatation xw4100
Well, u can order it from here if u want
http://www.cwc-group.com/d2808f3p.html
I dont think its worth repairing it, and tou dont nessasery need to buy an HP PSU, u can buy any PSU as long as the PSU have the same connectors
Good luck
Dec 09, 2008 | Compaq Creative Sound Blaster PCI 128...
HP Workstation Xw4100 PC Desktop Logo
213 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
