Question about Bunn GR10 Coffee Maker
My Bunn coffee maker is leaking water - Bunn GR10 Coffee Maker
  • Anonymous Jan 30, 2009
    i have older bunn pour-matic when i pour water in to brew it leaks outright-side rear about 1/4 cup
  • Anonymous Mar 28, 2014
    Problem Solver:
  • 19 Answers
Does it leak all of the time or just when you pour it in. There are a couple of solutions. There is a tank inside and a pan that leads the water to the tank. There is a gasket between the basin pan and the tank. It could be leaking from there but that is pretty rare. Generally what happens is that the basin may get chips or scale that builds up around the basin to tank access nut. The nut secures the basin to the tank with a flat,round silicone gasket between them to keep water from leaking. If scale impeads the free flow of water from the basin to the tank the water backs up and will give the impression of a brewer leak. I haven't worked on one in awhile but there are two screws that hold the pour over top to the brewer. The top can carefully be removed and a visual inspection is done (remember to unplug the brewer) to see if the access nut is clear. The lime could be in the nut or just below and inside the 3/8' hole that leads the water to the tank. Bunn makes a delimer spring that is used to clean out the sprayhead that I use to clean that nut. Speaking of sprayhead, if the leak happens during brewing and seems to come from the front take the brewbasket away and run about a half a pot of water through the brewer and see if it comes through the sprayhead's 5 holes. If it dribbles and doesn't fan out into the pot, or tracks along the roof of the brewer and drops down the side or back clean the sprayhead and try again. Also if it is the A10 or B8 I would run your delimer spring through it. If you don't have the spring you can get one at your local Bunnomatic representative's office. Or call Bunnomatic in Springfield, Illinois and they can send you one and instructions of how to use it. The picture of the bunn I am sending you is of a restaurant model but uses a pan just like the smaller bunns. This one is stainless but the principle is the same. The nut right by the 1/4" spicot is the water access nut, just like on yours. They will clog and leak, but I would check your sprayhead and the free flow of water from it before I do anything else. If it isn't either one of the solutions I have spoke about it could be a tank gasket or worse. Rick in IndyMy Bunn coffee maker is - 91db15f.jpg
Posted on Aug 21, 2008
  • 2039 Answers
SOURCE: BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Posted on Jan 29, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
SOURCE: my bunn coffee maker leaks
Experiencing same problem. Appears there may be a recall depending on your model and production date. I suspect it is the small seal washer where top fill tube attaches to the top of the tank. Water leaking here would flow done inside the round steel body and leak out bottom.
Posted on Aug 18, 2008
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Coffee maker leaks
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
May 27, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn GR10 Coffee Maker Logo
396 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
