Question about Dryers
I bought a new lint screen for my dryer because the old wouldn't go in all the way but this one isn't either. I was wondering if this was a common problem on this model and if there's a trick to getting it in properly. Thanks.
Use a flashlight and look into the space the screen goes. You will see lint built up and preventing the screen from going all the waydown. Remove the lint.
Posted on Aug 15, 2010
  • Dryers Master
  • 8,220 Answers
It could be that you dryer is overheating and has warped the filter. Seen it on Maytag brand dryers where the dryer wheel was stripped out and it took fifty forever's to dry a load.
Posted on Jul 11, 2010
How do u check to see if the dryer vent is plugged
  • Check your lint screen. If there isn't much lint on it and you've been doing laundry, it's possible the lint may have been caught in the vent instead of the lint screen, which means you have a clog. Lint in the area around where your dryer is can also be a sign of a problem. For More information please visit Dryer Parts.
Nov 08, 2012 | Samsung DV218AEW Electric Dryer
I have a build-up of lint and dust below my lint screen. I know how to clean my lint screen. Please let me know how to clean below lint screen in dryer cabinet where the air heads out of dryer.
I used a piece of bent metal clothes hanger to dig out some of the big pieces and then to dislodge the particles stuck to the bottom. First I tried my dirt devil and it wouldn't fit, then I brought in the shop vac. I have a roomba and no regular vacuum. The shop vac nozzle attachment was thin enough with some force to reach the majority and had the power to bring up the lint, dimes, and flossing tools. I use the shop vac with all extensions to clean my lint vent after removing the vent cover. If you plug the overflow in tub, the shop vac can remove hair clogs from the drain that accumulated from two long haired daughters for ten years. It can also unclog toilets (yuck), but has to be disinfected afterwards.
Sep 25, 2011 | Bosch Nexxt 500 Dryer
Dryer shuts down sometimes , sometimes gets too hot then shuts down until it cools
First thing you will want to check is the lint screen, if the lint screen is clean, check the venting system. Unhook the 4" hose behind the dryer and look into it to make sure it isn't plugged up with lint. Also, check the rest of the vent all the way to the outside of the house . If the vent is stopped up it will overheat the dryer and cause other problems down the line.
Apr 18, 2011 | Dryers
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
My Whirlpool duet dryers lint screen in the dryer don't seem to catch the lint anymore but, the varmet screen on the hood is clogging all of the sudden. We bought it in August and installed new stove pipe...
OK. to get this working again you want to get the vacuum in where the lint holder is.... then let it run and see if that works but im sure you might have to spend about 10 bucks for a new net
Dec 21, 2009 | Whirlpool Dryers
Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Oct 13, 2009 | Samsung Dryers
Lint screen is warped and does not collect very much lint
If the dryer is less than a year old the lint screen should be covered by warranty I would replace the lint screen to see if that helps.
Jan 06, 2009 | Kenmore 67082 Electric Dryer
A lot of lint is getting by the in unit filter screen and is cloging the outside vent bird screen The dryer is about one year old and is a model DHDVH52
Check the seal for the dryer vent coming from the drum itself. It may just be a simple lint filter replacement that is realitively cheap and can be bought from www.marcone.com. If it is a top removable lint filter, the seals get worn out quite easily. Also, be sure to clean the lint filter after EACH load to help prevent it.
Mar 15, 2008 | Dryers
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
50 people viewed this question
Top Dryers Experts
