Question about Kenmore 84152 Electric Dryer
Heating element went bad in whirlpool dryer replaced it and worked fine for about 10 minutes then it stopped heating. took element back off and it looks fine help me plz
  • Kenmore Master
  • 43,501 Answers
Hi, If you have a gas dryerheating element went bad in whirlpool dryer - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.giheating element went bad in whirlpool dryer - 2_bing.gifh_mi is electric2_bing.gif..
There could heating element went bad in whirlpool dryer - 2_bing.gifr of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshootingheating element went bad in whirlpool dryer - 2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
I HAVE kENMORE GAS DRYER SERIES 80. last week dryer would heat for a minute then go out. Dryer would spin with no heat. Wnt to appliance store told me to change heater fillaments that one was bad after...
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 17, 2011 | Dryers
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer was working fine then quit heating
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
Hello I have a whirlpool dryer model #LER7648KQ2 It is only 5 years old and it never went off last night I think the timer is broken and now it is not heating so is that a fuse or the heating element
Mine had the same problem. A repair guy (overcharge me) replaced a thermal fuse by opening up the back of the dryer, took 10 minutes. I can do it next time and save $125. Well lesson learned.
Dec 28, 2008 | Dryers
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore 84152 Electric Dryer Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
