Question about Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Pump is making humming noise but not turning on. This happened after a breaker blu. I reset breaker and this is what happened.
  • 990 Answers
This may just be the start celonide. Look's like a "D" battery or bigger in the back of the motor or on the top in a half round case. It is ment to boost the power to start the motor turning. If it bad the motor just humms till the breaker blows. Sounds like just what you have.
Posted on Jul 11, 2010
  • pizzles76 Jan 30, 2011
    Straight from hayward site. "You will usually hear this humming or jamming sound when you first plug in the pump, if in fact the motor is seized or jammed. Sometimes the frozen up pool pump motor will cause the circuit breaker to also blow". They say to "rubber mallet or small hammer and tap the motor casing all around. This will “free up” the surface rust enough so that next time you plug it in the motor will be able to spin".
    I did this, it worked real quick then started humming again. I had the back cover off, where the switch is, and you'll see the center where you can put a large flat head screw driver. I used that to turn the motor while plugging in the motor. Took a couple of times of the CB popping but it finally worked and now is running perfectly. Kinda needed a jump start!
Washer shuts off before spin cycle
Hello mjacoutot - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line. I would suggest resetting the unit; you can do that by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately. Unit may need the pump or timer diagnose.
Jan 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
Pump has power at back of motor and I can turn shaft at the back of pump. It is not running.
this motor has a run capacitor, have it tested. search your area for your local pool pump motor repair guy with free testing.. ask him how to remove it, caps can hold a charge and make for a nasty surprise.. THIS IS IF THE MOTOR HUMS OR MAKES A BUZZ NOISE if not, you will need to check the power at THE BACK OF THE MOTOR. no power check, timer, breaker, main breaker ..
Jun 06, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Submersible well pump poping breaker
The motor is locked and you cannot reverse it... the pump will need to be pulled and replaced...
Replace it with a "sandhandler" type pump that will pump the grit through it with out hurting it..
heatman101
May 24, 2010 | Flotec 075 HP Submersible Well Pump 3Wire...
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Making humming noise and trips breaker. not sure what happened
MOTOR I SHUTING DOWN DO TO OVERHEATING PROTECTION MOST LIKELY SOMETHING IN IMPELLER CHECK TO MAKE SURE SHAFT CAN TURN WITH PU OFF TAKE PLIERS AND TURN SHAFT AND THEN START
Jun 09, 2009 | Pentair 2hp 230v Ur Mh Challenger High...
Humming pump throws beaker
It's because you may have a defective starting capacitor or a stuck-up motor or pump. If you know how to check a capacitor, do so. If not try replacing the old one. If the problem still persist, try to turn the shaft with your hand. If you can't turn it. You might have a defective motor or pump bearings.
May 30, 2009 | Plumbing
Dryer
something stuck in blower. remove front panel to check better. may be possible to look straight down lint opening. if its humming and not turning, bypassing the door sw will not help but cause a safety concern.
Apr 27, 2009 | GE DBXR463EDWW Electric Dryer
Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP Logo
887 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
