Question about John Deere Garden
John deere 265 has power in forward but in reverse practically none
  • 479 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
try to service the old transmisson it may work.but if that does not work just replace the transmisson.
purchasing a new hydrostatic transmission is much advisable as its definately the problem of hydrostatic transmission with out any doubt .but i hope servicing the old works.
Posted on Oct 01, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: john deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
Posted on May 26, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
Prego john deere front loader wont go into reverse. it goes forward instead.
switch the wires around on the motors, it sounds like the polarity is reversed
Jan 05, 2014 | Peg Perego John Deere Front Loader
John deere sabre 2354 hv moves slow forward, even slower in reverse
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Mar 23, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere 826 will not go forward or reverse
Can anyone help me with a john deer 826 snow blower that won't engage in forward motion?
Mar 04, 2013 | John Deere Mowers Tillers Snow Blowers...
No reverse in john deere ''gator''
check to see if both wheels are spinning in forward, if not you have a bad motor
Oct 28, 2012 | Peg Perego John Deere Turf Tractor
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jul 12, 2009 | Garden
Gator 6x4 tranny problem
try posting the question in the forum for john deere gator and not the forum for the kids john deere gator
May 21, 2009 | Peg Perego John Deere Gator HPX
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
