Question about Fiesta Blue Ember Gas Grill
Appears that connection vibrates and makes noise
    Champion:
  • 274 Answers
When you say "connection" I am assuming you mean the hose and regulator and the regulator is humming. This happens under some very specific conditions, and is usually not a problem. You can replace the hose and regulator, easy to do and inexpensive, and see if it stops.
Posted on Jul 12, 2010
Vibration in rear end
There are several other things which can make a noise. The people you showed the car have the advantage of hearing or feeling the noise that we do not have a chance to do.
A catalytic noise can change with the engine RPM. You can rev up the engine in Park or Neutral and should be able to replicate the noise. If not, then you have a moving part making the noise.
Sometimes the Emergency brake material comes loose from the metal backing and jams inside the rear drum/rotors. It will cause vibration when pulling away from a stop, and eventually will grind into powder.
Rear axle differential clutches. There are friction disks inside some types of rear-ends. A special lube additive makes these work. Sometimes a refill of additive and lube can make marginally performing units more quiet.
U-joints can make noise and vibrate. Its another moving part noise.
The fan clutch can also make noise and vibration. The A/C compressor and compressor clutch bearing can make noise. The A/C clutch operates intermittently depending on pressure and temperature.temperature.
Apr 15, 2014 | 2002 Ford Thunderbird
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
After 8 years of working well the machine vibrates violently. At slow speeds it is not too bad , as ithe spin rate picks up the machine seems to be trying to tear itself apart and I need to shut it down....
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Jun 10, 2010 | Horizon AFG 5.0 AT Treadmill
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
BMW 2001 325xi Power Steering noise / vibration
no filter, sounds like the steering rack is worn out and need to be rebuilt.
Apr 22, 2009 | BMW 325 Cars & Trucks
2006 Ford Ranger vibration on steering wheel and noise @ 110 Km/h
Check your brake rotors and make sure they are not warped. another option could be a wheel bearing issue but i think that would be highly unlikely(they usually whine and it get louder as you go faster)
. Also to look at is did this suddenly appear AFTER you had the truck's shocks serviced?
If so then have another shop check it over and explain to them that one shop did such and such service..got a vibration/noise and could you check the safety of it? loose bolt...a forgotten part..you get the idea. hope i gave you some leads at least.
Mar 13, 2009 | 2001 Dodge Stratus
Loud noise appears to be coming from the engine
what kind of sounds is it making a knocking sound or a exhaust sound might need a tune up
Oct 20, 2008 | 1995 Oldsmobile Cutlass Supreme
Fiesta Blue Ember Gas Grill Logo
103 people viewed this question
Top Fiesta Grilling Experts
Paul Carew
Lawrence Oravetz
ray gallant
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
