Question about Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Washer CCU
Which electronic control is considered the CCU? I'm getting the F01 error code and am going to replace the CCU as instructed in the diagnostic guide and as successfully done by many on this site to fix the problem I am encountering. In the Sears Parts Direct diagram there are 2 different Electronic Controls and I'm not sure which one is the CCU.
This is for model 110.4751.2601.
Thanks in advance.
  • Kenmore Master
  • 2,605 Answers
Welcome to Fixya.
The central control unit, aka "CCU" is the control located to the right of the main console when you remove the top. ( approaching from the front )
The part number you want is W10205848 as listed by "searspartsdirect.com". ( Also available at many on-line vendors such as "repairclinic.com" which use there own stock number 1547531 )
I do see a fair bit of these since I am presently a Sears service technician ( after being independent for over 15 yrs. it`s an adjustment...but that`s another story :P ).
It should look like the image I`ve attached to help you identify it more easily...
Hope this answers your question. Thank you for choosing "FixYa" for your repair needs.
Please take a moment to rate the info I provided for you here and a testimony if you feel it warranted.
Thanks again and good luck.
macmarkus :)
Posted on Jul 11, 2010
  • 3 more comments
  • Gillian Dionne Oct 08, 2010
    How do you remove the front panel to access this?
  • Mark MacDonald
    Mark MacDonald Oct 09, 2010
    There. Should be no need to remove the front for the ccu to be service/replaced. You will need to remove the top panel. To do this will only require removing the screws at the top panel on the back, followed by sliding the top back an inch or two and up. The ccu will be to your right when facing the front as indicated in my initial post.
    Regards,
    Macmarkus :)
  • steeelerfan
    steeelerfan Jul 16, 2012
    If I have the model # 110.-47532602. Would the part number be the same as you described above?
  • Mark MacDonald
    Mark MacDonald Jul 16, 2012
    Steelerfan,
    Part number is W102check 05849 if your model is indeed a 11047532602. Double on the link provided here for your own assurances.
    http://www.searspartsdirect.com/partsdir...
    Thanks for choosing FixYa. Good Luck !
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Sorry, incomplete number. Should've been W10205849. :)
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
110.4753 error code f01
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
Central Control Unit
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
Mar 31, 2014 | Kenmore HE2 Plus Front Load Washer
KENMORE HE2 F01 CODE
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 30, 2010 | Kenmore HE2 Plus Front Load Washer
82822 / 82824 / 82826 Electric Dryer: kenmore HE2 electric dryer, beeps and all display ...
May 17, 2010 | Kenmore 82822 Electric Dryer
Getting error code F1 and don't know what it
Apr 19, 2010 | Kenmore HE2 Plus Front Load Washer
I have a F01 code
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Apr 13, 2010 | Kenmore HE2 Plus Front Load Washer
F1 error on Kenmore he2 plus model 4619790225122
Feb 09, 2010 | Kenmore HE2 Plus Front Load Washer
My front load he2 washer model # 11047561601 won't start it has a error code that says f01
Oct 10, 2009 | Kenmore HE2 Plus Front Load Washer
My he2 kenmore washer is not starting when i push the button-it stops and starts flashing the error code f-01-what can I do to fix the problem?
Sep 26, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE washer gives error F01. What can I do?
Apr 07, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,724 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
