Question about Dryers
My celing fan is wobbling, how do i fix it? - Dryers
  • firebaseamer Jul 11, 2010
    I have no idea what brand celing fan it is but it wobbles really bad. I tried putting weight on various blades thinking that might help...LOL didn't.
    Brigadier General:
  • 3,006 Answers
Ceiling fans need to have balanced blades if they are not to wobble. At it's simplest this means that all blades should weigh the same, and they should all be exactly the same shape. But it's not quite as simple as that, as the brackets that each blade is secured to also have to be balanced.
In practice, good quality fans will have the blades carefully balanced by the factory, and on better quality models the blades will be matched to individual mounting brackets in which case there will be markings to identify which bracket goes with which blade (and also to identify where each bracket mounts to the motor).
Cheap fans (almost anything under £130) will not be carefully balanced and so whether they wobble or not is a matter of pot-luck.
To try and cure your fault, first remove and accurately weigh each blade complete with the brackets attached. You can buy strips of self-adhesive balancing lead to add a gram at a time to the upper side of the tip of any blade which is under weight. Note that if any blades are damaged, you must repair the damage before weighing. If any blades are twisted along their length (normally they're simple flat paddles set at identical pitch angles by the way the brackets are shaped) then they must be counter-twisted to match the other blades. Also, check for manufacturer markings to see whether there are any suggestions as to which blade goes with which bracket and whether the brackets are marked to match a particular mounting point on the motor (usually simply by matching coloured paint blobs).
Once you have checked all that you can, see if the wobble remains. If it does you should try swapping the brackets around on the motor: by doing so you'll normally remove the wobble altogether or will considerably reduce it. You might not achieve perfect balance, but you may get to a point where the resonances which cause the wobble offset each other.
A well-balanced fan will not wobble appreciably at any speed, a less well-balanced example might still wobble at some speeds and not others.
I hope that I've helped and that you will take a moment to rate my answer. If there's any part of my reply which is unclear to you then add a comment and I shall try to assist you further when I'm next online.
Posted on Jul 15, 2010
  • Obertelli
    Obertelli Jul 15, 2010
    One extra point: if you don't have suitable scales, you can weigh the blades against each other simply by suspending them from either end of a beam (such as a wooden ruler or a bit of timber lath) which you've suspended from the centre. Once you have two blades weighing the same, you can weigh the others against them in turn. Blobs of Blu-Tac are useful as temporary weights, but should be replaced with identical masses afterwards as they tend to fall off over the longer term. Whatever weights you add must be really secure as you don't want them to spin off and cause injury or damage.
  • AsshoIe Sep 23, 2010
    Check the downrod and see of the screws are tight abd if it loose, it will make it more sentitive.
Our ceiling fan is having a major problem it has an ac hum that goes right through you can you please help us to solve this problem?
Put a small piece of card board between the mounting bracket and the celing/outlet box. this will dampen the noise, and hopefully fix your problem.
Jul 11, 2010 | Aloha Housewares (93645) Ceiling Fan
Although this is posted in completely the wrong category, I shall try to assist you.
Jul 11, 2010 | Meade Capture View Binoculars
My craftmade celing fans/lights start strobing
SOunds to me like you have a bad wiring connection in the fan unit, have someone check out all the connections, both between the fan and ceiling and the fan and light unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 18, 2010 | Craftmade International Electrical...
Cannot stop the ceiling fan from wobbling. Have
you still have a blade that is out of balance. mesure each blade from the bottom side end to the celing in one spot. Do this for each blade when you find the one that is closest to the celing then you have to place the wheight on the edge of that blade then spin it to make the right adjustment then seta stick on weight where the temp. weight is at
Jul 31, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Dryers Logo
537 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
