Question about Soyo (SY-P4VTP) Motherboard
I NEED THE STAT RAID DRIVER
I DON'T WAND ANY ONE TO SCAN MY COMPUTER JUST NEENTHE DRIVER
    Novelist:
    Champion:
  • 226 Answers
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Posted on Jul 12, 2010
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Where can i download raid drivers for my caliber xn9010?
The driver you need is based on your raid controller on your motherboard or if you have one your raid card, so you need to determine the motherboard manufacturer or raid card manufacturer and get the chipset drivers from their website.
djbr1ck
May 12, 2011 | Cybertron Caliber XN9010 Server
Need raid pata driver for foxconn rc4107ma motherboard
Normally RAID setup on board, is handled in the BIOS settings.
Feb 21, 2010 | Computers & Internet
I have a toshiba labtop with 2 hard disks working as raid. but I have formated my computer and now I lost the raid technology , so how can I restore it. I have the recovery CD and it should do it...
u will need a os setup disc which contains sata/raid support. u can make this setup disk. find out which sata/raid text mode drivers needed (i can't tell u which txt mode driver is needed as i don't know the model no. of the laptop)
find textmode driver needed for your model no. using google.
copy os setup disc(windows) on to the hard drive. use nlite to integrate textmode sata/raid driver. burn a bootable disc.
Recovery disc wont work as u have already formatted the drive.
Oct 06, 2009 | Office Equipment & Supplies
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
In to installation stat hdd not detected how
check the cable see taht the cable is alright and see tomthe bios setting unplug n plug again
Jun 19, 2009 | Computers & Internet
SCSI/RAID Host Controller/Driver cannot be found
Windows cannot find the correct drivers for this device. So, let's research a little bit.
Are you using SATA or RAID on the computer? If not, there is nothing that needs fixing.
If you are, then reinstall the RAID software from your motherboard installation disk, which should repair this issue.
If you do not have the driver installation disk from your motherboard, for whatever reason, go to their website. Almost every motherboard manufacturer provides easy access to drivers.
good luck
tony
May 22, 2009 | Computers & Internet
About operating system
That depends on how you want to set up your system. If you want multiple hard-drives to work together as one, yes, you will need to load RAID drivers during startup. If you do not want multiple hard-drives to act as one large hard-drive then no, you will not need to load RAID drivers during startup.
I would not recommend loading RAID drivers if you only have one hard-drive. RAID is for two or more hard-drives in the same computer.
Feb 18, 2009 | VIA MSI K8M NEO-V K8M800 Chipset 800MHz...
NVIDIA GeForce FX 5200 low megapixel rate
yeppers..in your system profile, you may need to shift how your processor is handling files. move pointer to maximum performance, or maximum resolution. can't have it both ways.
didn't see how much memory you have on board.
got backup?
Feb 14, 2008 | Computers & Internet
Restarting
before it start to do that was the computer freezing it sound you haqve problem with thr mother board check you power bar good luck cheers
Jan 18, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Soyo (SY-P4VTP) Motherboard Logo
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
