Please let me know how old is this tv insignia nscL26c thank you
  • joaorocha73 Jul 11, 2010
    realy helpful thank you
  • 505 Answers
It was produced in 2007
There usually will be a manufacture date on the back of almost all electronics, look by the model number and serial number, it should give an exact date and year.. if not, suspect it to be an '07 model
Posted on Jul 11, 2010
Pairing for insignia tv
Please expand your question to include some details about what you would like to know. Thanks.
Feb 19, 2015 | Insignia Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
I need a power cord for Insignia NS-L42Q-10A tv? Are they available, and where?
Hi there, (as far as I know :P) all these tv/monitor cords are the same...you can even use the one from your home computer. If you have a homecomputer try that powercord, if that works. then thrifstores are full of these for around a dollar. Radioshack and the like will have them too, but it could run upto $20....You can also try computerparts stores...These cords are all over. I have an old crt monitor of wich the power cord fits into my 2008 32" lcd tv....
Good luck and if this has (or not) helped you, then please rate, thank you!
Feb 03, 2010 | Insignia NS-L42Q-10A LCD TV
VCR picture with INSIGNIA 26'' lcd tv
I would check if you have selected the correct tv input on you remote. the shadow movement you see may be bleeding over from another input. on your TV remote you will see "input", keep clicking it, delaying a little each time, until you get to the correct input you are connected to.
Apr 07, 2009 | Insignia LCDTV26 26 in. Television
Insignia lcd 37''powering off and right back on by itself!
Hi Ed,
Since the TV is less then a year old and still under manufacturers warranty, I would suggest to take back to the vendor to get it fix because this LCD behavior is not going to get any better.
The failure on this TV is related to a power supply in most cases if the TV is turning OFF by itself or needs to be unplug to let cooldown and it works afterward.
Feb 28, 2009 | Insignia 37" LCD Flat-Panel HDTV
Volume
Sounds like it's locked. Either hold the remote control "DISP" down for 3 seconds, or press it repeatedly about 10 times & it'll unlock.
Jul 16, 2008 | Insignia NS- 27" TV27 TV
Code for cable TV remote - 26" Insignia 720p HDTV
I just bought a 32" Insignia NS-LCD32-09 using the Cox (suddenlink) remote and the code 0463 worked fantastically for me, Thanks!
May 01, 2008 | Insignia LCDTV26 26 in. Television
Insignia TV doesnt turn on
noavatar_s.png Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Insignia Polaroid Advent Audiovox
ISLCDTV32
lcd
Tries to start then Shuts down!
Insignia IS-LCDTV32 , Polaroid FLM2601 andFLM3201, Advent 203L32K50B Also Audiovox FPE 3205 LC32K5. Cure:Replace the three 680uf at 35 volt caps at the top left of the power supply board.
It works!! I replaced the caps--about a buck each. The bad caps were swollen, and soldering in new caps wasn't hard to do. THANKS!!!
Feb 02, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
