Question about Frigidaire GLWS1339C 3.0 Cu. Ft. Top Loading Washer
Frigidaire top loading washing machine will not
My Frigidaire top loading washing machine will not spin or drain. We had a power outage while clothes were in the machine. After the power came back on I checked the washing machine. It was filled with clothes and water and had stopped working. I pulled all of the clothes out and placed them in the sanitary basin next to the machine. Then, I emptied the machine of water. Then, I tried to run a ''test'' load. I reset the water level to lower and started the machine on a 6-minute cycle. The tub filled, but the water never drained. I also noticed that the safety latch did not move into place. Is there a way to reset the machine?
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 125 Answers
SOURCE: Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Posted on Jan 09, 2008
Coldcut
  • 1554 Answers
SOURCE: Frigidaire Gallery Front Loader doesn't spin
The CCU board is likely at fault see one of my discussions on this here
these boards have intermittent failures that will drive you wacky.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Feb 14, 2008
sdmc73
  • 121 Answers
SOURCE: neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Posted on Nov 30, 2008
Ben-mrfixit
  • 68 Answers
SOURCE: SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
Posted on May 02, 2009
The washer is not spinning to get the excess water out of the clothes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin goes through all cycles but clothes are left soaked
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 16, 2011 | Frigidaire GLTF2940E Front Load Washer
Not spinning clothes
heatman101
Feb 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer is not spinning out wet clothes.
heatman101
Dec 26, 2010 | Frigidaire Washing Machines
Smells like smoke and my clothes are still wet
heatman101
Oct 28, 2010 | Frigidaire FWS933F Top Load Washer
Washer will not complete spin cycle clothes are still wet
Sep 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLT F 2940 ES Front Load washer. Spin is slow. Clothes wet
heatman101
Sep 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My washer won't spin. My clothes are still wet and the soap is still on them at the end of the cycle. Do you think it is the belt?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Frigidaire GLWS1339C 3.0 Cu. Ft. Top Loading Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
