Question about Vacuums
I need a replacement battery fo my vacuum xb640h 8.4 volts. where can I purchase one?
  • Anonymous Jun 06, 2008
    I have three dirt devil scorpion hand held vacs - model 0882. I need a replacement battery for one of them. I have read the manual about removing the dead battery, but there is no mention of where to find a replacement. I contacted "Batteries Plus" and they said they would have to "build" a replacement battery at the cost of 21.99!!! That's more than a new scorpion costs!! I purchased them on 10/6/06 - It is my understanding that there is a 3 yr warranty. It seems like they should last longer than 1 & 1/2 yrs. Please help me with this problem. We love the product!!!
    President:
  • 1,673 Answers
Find a repair shop that repairs what ever brand this is and see if they can get one for you.
Posted on Apr 20, 2008
Need charging station for Shark Cyclonic 12 volt cordless power-vac
Buy a replacement charger from the Shark Cyclonic dealer. It is important that the specs match the battery, one or two volts higher can shorten the battery life by quite a large amount.
Aug 03, 2015 | Shark Vacuums
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Do I need to replace the battery as my dustbuster does not seem to have a lot of power and therefore does not pick up as it used to?
Yes the battery is most probably the problem. you can check is the voltage of the fully charge battery is same as what is stated on it, if not you definitely need a new battery
Mar 05, 2011 | Black & Decker 15.6 Volt DustBuster Vacuum
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Brand new : battery charges to 60 minutes ( 8 hours)and by the next day is completely discharged.
It sounds like the battery has a faulty cell in the battery that never lets it hold a full charge or lets it bleed off. I would take it back and exchange it.
Could you provide a model number?? There may be some settings on the vacume that are continuing to use power even though it is not in use.
Thanks
Apr 11, 2010 | Vacuums
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Vacuums Logo
211 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
