Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Keeps going to refresh mode
Every 10 min i get a prompt on my screen saying  picture going to refresh mode then goes black screen with a video 1 on left hand corner
  • GoBrowns Apr 30, 2008
    I have the same issue. I can's seem to find a way to turn off the "refresh mode" so it won't show me the message every 10 minutes or so. It is quite annoying and I would like to shut that feature off. Please post a response if you know how to fix this. Thanks, Dan
  • bill
    bill Oct 26, 2013
    ok when you turn on the tv just hold the power button when it turns on until it rests and turnes back on it will show home and display setting hit home
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Posted on Nov 27, 2008
*** I Found out how to fix this problem. You have to reset your TV. Menu, Setup, Reset. As when the tv is put up, if on display at the store, it is initially set to "store mode". When the tv is first put on, there is a prompt message that asks to if the tv will be running in a store or at home. The refresh mode is a new feature for stores as it shows every input features. Video 1 quality , HDMI, etc... For customers. So reset your TV and the problem is solved.
Posted on Jul 12, 2008
  • Robitaille Jul 12, 2008
    *** update! reset does not quite cut the trick. the actual solution to have the option to chose from home or store mode is to unplug the power from the tv from your wall for about 5 seconds , plug it back then turn the power on with your remote. the choose the home option. Problem Solved!
You rock! Thanks for this answer!
Posted on Oct 26, 2008
I have that same f@#$ing problem here too!
Posted on Jul 11, 2008
Same **** here
Posted on Jun 17, 2008
Dude i got the same prob and have no idea how to fix it
Posted on Jun 07, 2008
Why does my gateway fpd2185w monitor screen go black after showing my desktop for about 1 minute
David
That problem is calle,refresh, thats happend when the monitor try to refresh the page or "clean" the page, you can set that in your video driver options. but if you don't have a video driver for your particular video card already installed, you don't have a right refresh rate and this delay, may happend.
Carl
Mar 22, 2016 | Gateway Computers & Internet
Just installed a ZR24W monitor, screen blacks out after 10 minutes with a message saying 'Input signal out of range, change settings to 1920x1200-60hz'. The monitor was set to this resolution &...
You will need to adjust the refresh rate of your system.
1) Right click on the desktop and go to properties.
2) When the Display Properties window opens go to the Settings tab.
3) The go Advanced.
4) Once ni the advanced screen go to the Monitor tab.
5) Under screen refresh rate select around 60Hertz. (Make sure the box next to "Hide modes that this monitor cannot display" is ticked.
6) The click OK. And OK again to exit Display Properties.
May 26, 2011 | HP Smart Buy ZR24W LCD Monitor
My sansa e260 goes black after showing sandisk start up screen and does the same when plugged into a pc. it starts to refresh database and then the screen goes black.
Hi there
When you say the screen goes black even after disconnecting the device from computer it could be an issue with the firmware.
It might need to have updated firmware. To get the updated firmware please go www.sandisk.com.
Where you can get the latest firmware for your model.
*** Make sure when you update the firmware keep the device in MSC mode.
Here is the link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Kindly revert for further clarifications....
Feb 17, 2010 | SanDisk Sansa e260 MP3 Player
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Every 10 mins my monitor goes black and then the picture pops back up
Its the poblem of SCREENSAVER which gets activated every 10 minutes.
In Control Panel, go to Display Settings / Personalise - - - - -> In Screen Saver select NONE.
Your problem will be solved for sure.
Apr 24, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
I GOT A PANASONIC PLASMA TV 2 DAYS AGO..SINCE THEN EVERY 5 MINS A MESSAGE SHOWS UP ON THE MIDDLE OF THE SCREEN SAYING: "NOW IN PICTURE REFRESH MODE. GOING TO RESET SETTING" HOW CAN I FIX THIS...
  • Unplug the TV and plug it again.
  • Press and hold down the front POWER button.
  • If TV doesn't power up, use remote power on while holding down the button on the set
  • You will be prompted to chose between STORE and HOME mode... select HOME
You should be good to go.
Jul 09, 2008 | Televison & Video
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
1,844 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
