Question about Schwinn Original Airdyne
The handle bar got very loose while i was using it it suddenly went to the left this is a staionary bike the schwin areodyne can i fix this? i cannot afford repairs seems there is a big lug nut holdind bar to foot rest i think that may be the problem but just dont know please help i think it is a original but not sure
  • 16 Answers
Http://www.fitnessrepairparts.com/diagram/113 This is an on-line link to the schematics for your Airdyne. The large nut between the handlebar (foot part) and the wheel hub are supposed to be pretty snug. Tighten the nut using a 6 or 8 adjustable wrench and tighten the nut clockwise. Be careful not to tighten too hard or the handlebar will not move at all. This is a very easy fix.
Posted on Sep 27, 2010
My bikes handlebar is coming out on the left side. I don't really know anything about bikes so I need help. (Its a 26" Huffy Mountain Bike)
On the steering stem were the handle bars go through there will be a clamp. This clamp will have one, two or four bolts tht clamp the handle bar.
Depending on the type of bolt used on your bike you will need a ring, socket or allen wrench. Loosen these bolts of about two turns anti clockwise and center your bars and then tighten the bolts.
May 31, 2015 | Huffy 26201 26-inch Mens Granite Hard Tail...
Lots of vibration in front end of bike
could be a lot of things, something loose? wheel out of balance
shock absorbers, head bearings out of adjustment or damaged.
watch your speed until you get it fixed
Oct 27, 2014 | 2008 Big Dog K9
Stripped handle bar adjustment piece
Your bike appears to use an adjustable stem, which allows rotation to change the height/reach. Although such stems are a fairly new feature, they have been successfully used for several years. Apparently the one spec'd for your bike is not very sturdy. See the posts below from two people who had a similar problem. I suggest you complain to Walmart and ask for a fixed position replacement or a partial refund so you can choose your own stem.
My latest love hate bike the Genesis Onyx 29 beach cruiser
Genesis Onyx 29 Cruiser
Oct 16, 2017 | Cycling
My MTB handles seem to be to loose , when I let go of the handles there is no stability. How do I set this?
This sounds like te neck of the bike has come loose, tighten the bolt that's right above the frame and underneath the handle bars, there will also be a little washer-type thing that's directly under the bolt and you must tighten that in order to shield the bearing from moisture. hope this helps, Daniel
Oct 29, 2010 | Mountain Best Bikes NFL Michigan U 26-Inch...
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
Schwinn Original  Airdyne Logo
247 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
