Question about Nintendo Wii Console
I am trying to hook up my Nintendo Wii to my samsung tv and it says no signal
  • 2,272 Answers
Check the AV Inputs on the wii and the t.v. Select proper input on tv as well. Interchange the wires too and check. Well, the yellow wire which represents the video, generally goes into the middle port of the set of three ports which connect the RCA cables you're using. The red and white wires go into the ports on either side. The rings around the ports are usually colored to indicate which wire goes where, so try taking a flashlight back behind the TV to see where these wires go next time.
Your TV may also be on the wrong input. Turn on the Wii, and try switching to all of the inputs one at a time next time.
Check out.Thanks.
Posted on Jul 11, 2010
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
How do i connect my nintendo to my samsung led tv
I am assuming that you are talking about a Nintendo Wii.  When you buy a Wii it comes with standard RCA composite cables that are three colors, Red, White and Yellow.  Yellow is the cable that carries the video signal and the red/white carry the stereo audio signal.  You would need to connect these cables into the corresponding color inputs on your tv.  Plug the yellow ended cable into the yellow jack on your TV and do the same for the red and white cables.  After this is done, you will need to switch your tv's input to the input that corresponds to the one you plugged those cables into.   Some newer flat panel TVs do not come with RCA composite inputs.  If this is your problem, you will need to get some component cables for your Wii.  These cables look identical to RCA (composite) cables but come in colors red, green, blue, red and white.  In this case the red, green and blue cables carry the video signal and the red and white carry the audio.  You can purchase these from just about any store that carries the Wii or online from places such as Amazon.com.
http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
You would hook these up the same way by matching the colors and then changing your tv to the corresponding input.
Hope that helps!
Jun 27, 2011 | Computers & Internet
My Wii console will turn on, but no signal is received at the TV. The console powers up, you can load and eject discs into it but nothing comes up on the TV. I tried switching TV's and it still didn't...
If you switched tvs and no help than that tells you that the cable that hooks the wii to the tv is probably bad try a new component video or rca cable whichever you are using
Apr 17, 2011 | Nintendo Wii Console
I hooked up my wii to my samsung tv and the tv does not find the input. I tried two different input areas on the back of the tv and no luck.
The remote should have a button labeled 'Input' or 'TV/AV' or something similar, this cycles the TV through each of its input modes (DVI, HDMI, RCA, Component, etc)...as you click to each one wait several seconds as the change over usually takes a couple seconds.
If this does not work verify cable attached properly. Im assuming that your Wii is working fine on another TV and so it not sending a video signal is not the issue?
Feb 19, 2011 | Nintendo Wii Console
Plug wii in and turn on and get nothing. the tv
If it isn't turning on the power cable probably needs to be reset. Unplug the power cable from your Wii and the wall and let it rest for 10-15 minutes. It sounds silly, but try it. Nintendo built in a reset mechanism for power adapter failures.
Jan 24, 2010 | Nintendo Wii Console
How to connect a wii to my tv
Please take your AV Cord and hook it up to your wii and your tv. There are 3 colors. Red/White/Yellow
Once hooked up, take your remote and switch the Video Input on your tv. (look for the input button)
Make sure the Wii is powered on and you should see it pop up on the screen.
Dec 31, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
