I am running windows XP on my computer. The PC is able to detect the 3com 1/100 lan card. But I still can not connect to the internet. I can not download the latest updates to my NIC. what should I do?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details
Thanks for using FixYa.
Posted on Jul 18, 2010
I hace dual boot on a drive xp and vista 32 bits. i get correcr maaac address in xp but mac address in vista is different. i have LAN internet connection. therefore i cannot get connected to internet in...
MAC address need not be changed to connect to internet, unless the cable modem you have is configured in such a way that it only connects to a particular MAC address.
The solution is to change the settings in the cable modem or the router you have.
Please specify the following details
1. if you have windows click on start and click on run(for xp) and type cmd and hit enter
2. type ipconfig and hit enter
3. Find out what is the IP address specified there it should be in the format - 192.x.x.x
4. Note down the address against default gateway
Do the same thing for both the computer and then let us know so that we can narrow down the issue and suggest a better solution
Feb 04, 2011 | 3Com : 32-bit 10/100 LAN CardBus PC Card,...
I have a IBM thinkcenter 8123 model. I can't install lan due to lac of suitable driver! pls help me!
Go into the bios on your computer and shut down the onboard LAN, find a 3com or realtek LAN card and install it, windows has the drivers build in for most 3com cards, then you go to IBM site, download the drivers you need for the onboard LAN connection, remove the 3com card let the computer boot up, and when it asks for the driver point it to where you downloaded the drivers for the onboard LAN.
Jun 18, 2010 | IBM ThinkCentre M50 8187 Desktop PC -...
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
INTEX LAN Card 8139D RTL problem
you need to download the driver for your lan card. If the LAN card came with your computer, go to the computer manufacturer website to get the driver
Jul 04, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
How to make a pcmcia 3Com 3crwe737a working on XP ?
Hope this is what you are looking for...
http://www.3com.com/products/en_US/result.jsp?selected=5&sort=effdt&order=desc&sku=3CRWE737A
Have a nice day.
Jun 24, 2008 | Microsoft Office Outlook 2003 for PC
Linux Connection to WGA54G
first, check your cable. loose cable connection often lead the cause of that error. second. check the lan card of your linux pc. If your pc is a desktop type pc, try to replace the lan card and . Make sure that the lan card is detected by your system. try to connect on the internet again.
A Simple Thanks is Good Enough
Feb 13, 2008 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Ethernet driver does not work for IBM Thinkpad A20m
hi good day to you I have problem in my laptop thinkpad A20m PIII 700mhz 256 ram running in widows XP,, and everytime I install the driver of Lan the massage appear error in code 10, and the lan is not working,,can you help me in this problem?
Jan 12, 2008 | IBM ThinkPad A20M Notebook
3Com ISDN lan Modem-Model 3C892
Are you cable user? register the modem's  mac address to Internet service provider.
make sure that the Local area connection IP address of you PC  is not static.
Oct 07, 2007 | 3Com OfficeConnect ISDN Lan Modem Router
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
