Do i Turn the Power off ?
Seagate st310005fdb2e1-rk. 1TR external hard drive.
Urban legend says that i need to turn the power off when not using my external hard drive or it will fry. . (this model has no power swtich, so i would be unplugging the power supply and re-plugging it). Is this true. ? One person out of 2 says i need to disconnect the power supply until i want to use it again but no one will tell me 100% for sure.
Can i leave it plugged in, with power on, on the idle setting or should i unplug it to stop it from burning out.
Much Thanks
    Brigadier General:
  • 4,044 Answers
No one will say 100% either way because there is no 100% answer. If you leave it plugged in at all times it will most likely burn out the power supply faster than if you disconnect it when not in use. It was not intended for constant on situations or designed for that. You should be able to unplug the power from the external hard drive itself however that won't save your power supply. I would put it on a power strip with a switch and use the switch to turn it on and off when I needed it.
Posted on Jul 11, 2010
Hi, I have a seagate ST3160203U2-RK problem with turnng it on the power adapter has a green light but when turn power supply on the hard drive, the green light on adapter goes out - the hard drive does not...
It sounds like the controller for the drive is shot. You will probably need a new enclosure as long as the drive itself is OK that should do it. What is probably happening is that the controller in the enclosure is broken and trying to pull too much power.
May 17, 2011 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Lost power supply for Model#ST3400801CB-RK
The power supply for this drive is not ordinary. This means it has two pairs: 5.0V (1.5 A) and 12V (1.5 A) of power pins
http://www.ixbt.com/storage/maxtor-ext/seag400gb/powersup.jpg
Connector is S-Video like type
Feb 13, 2009 | Seagate 400GB 7200rpm External HDD Retail...
Seagate 300GB ST3300601U2-RK
usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Jan 30, 2008 | Seagate (ST3300601U2-RK) (ST3300601U2RK)...
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
