Question about Craftsman 25cc Gas Line Trimmer
How to adjust the fuel on a 32 cc craftsman - Craftsman 25cc Gas Line Trimmer
    President:
  • Craftsman Master
  • 1,545 Answers
This would have to be done by turning the High and Low speed jet screws which are unique in that they are round and have splined heads on them. A special tool is availabe to turn these 2 jets or you can make a homemade tool to do the same job. The screws were preset by the carb manufacturer. Aluminun tubing or even 1/4" brake tubing tapped on the jet heads or 22 Gauge female spade terminal disconnects stuck on the end of a screwdriver blade can be used to turn these odd headed jets. A jewlelers tiny needlenose pliars will work also. The factory preset for these screws is important to note and is approximately 1 1/2 (one and one half) turns out from snug...not tight.
Posted on Jul 11, 2010
Craftsman 32 cc 4-Cycle Backpack Blower won't throttle
I wouldn't try too hard to fix ANYTHING that's brand new! This is what a warranty is for!
May 31, 2012 | Craftsman 32 cc 4-Cycle Backpack Blower
Craftsman 32 cc trimmer is 5 years old never tuned it up. Now it will not stay running.
Here is my Tip on this problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
If you have already turned the adjusting screws, you may need another one of my Tips.
Just let me know.
Jim
Aug 15, 2011 | Craftsman 25cc Gas Line Trimmer
32 cc weedwaker mod#358791072 starts fine, will run at idel for warm up, dies when you give it gas or start it with choke in run position.
If you only have one jet screw adjust the "H" Jet screw on the carb. Make minor adjustments of less than 1/8th turn. Test engine acceleration after each adjustment.
If you have 2 Jet screws "L" and "H" only adjust the "L" screw.
On the 2 jet carb the "H" screw is adjusted for ideal top engine RPM / Max speed.
The goal is to elimate engine hesitation / stall as you grip the throttle quickly by adjusting the "L" jet screw..
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Craftsman Garden
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
I have a 32 cc craftsman convertible gas trimmer and I need to know what the tool is called to adjust the carburator?
the tool is Poulan Part Number 530 035560 and can be purchased at http://cgi.ebay.com/POULAN-CRAFTSMAN-HUSKY-CARBURETOR-ADJUSTING-TOOL---NEW_W0QQitemZ280351588986QQcmdZViewItem or just google the part number and you will find it.
Lee
Aug 12, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman 32 cc
theoretically the primer ball is the t connector.
Aug 01, 2009 | Craftsman 25cc Gas Line Trimmer
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32 cc
Your gas cap is probably clogged with dirt. The next time you run the trimmer and it begins to stall out, loosen the gas cap, it should start to run good again. Gas cap must be able to breathe in order for gas to flow properly.
Jim
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 25cc Gas Line Trimmer Logo
249 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
