LOOKING FOR INSTRUCTION FOR GAS FURANCE NORDYNE FG6RK 096N-16B -WOULD LIKE INSTALLATION AND PRODUCT INFO
  • Heating & Co... Master
  • 3,328 Answers
Nordyne have there own wed site google your furnace or nordyne info is all there
Posted on Jul 14, 2010
Looking for Intertherm MGH-075-ABWN-05 gas valve Model 36c67 type 177
WHITE-RODGERS Type 36C67 - Emerson
www.emersonclimate.com/Documents/White-Rodgers/instruction.../0037-5838.pdf
Type 36C67 complete gas control combines into a single compact package the functions of 3-position Gas ****, pressure regulator, 100% shut-off automatio pilot, main operator and Natural-LP Gas Selector. Termostat Circuit Current (24 V Model):. 0.23 Amps. Pilot Gas Outlet: Located at outlet end of the valve. Type of Gas:.
Need refurbished gas valve & tube - mobilehomerepair.com
https://www.mobilehomerepair.com > ... > Nordyne Service & Repair Feb 9, 2014 - The gas valve model is 36C67 Type177 part# is 6243700 ... Two are a electric oil radiator type & the other two are electric grid type. ... guys that you had to rebuild for me hoping it would solve my Intertherm model MGH-055-ABW36C67 gas furnace not heating up hot enough but did not resolve the problem.
36C67-175 - Hvac Controls - Amazon.com
https://www.amazon.com/Unknown-36C67-175/dp/B003WZWGDE Rating: 4.3 - ‎4 reviews
Product description. Robertshaw, Coleman, Evcon 24V, 1/2" x 1/2" inlet/Straight outlet, Dual Standing Pilot, Step Opening, Mobile Home, Gas Valve Replacement w/Two 1/2" Side Outlets & Reducer Bushing (1/2" x 3/8") ...Missing: intertherm
Apr 07, 2018 | Intertherm Heating & Cooling
I recently replaced my furance in my moblie home an now o have a Intertherm gas furance and i would like to have owners manual with it it did not come with one thank yoiu
Hi, most of the time, they tuck the manual in the heating section of the unit. Look around and you may find it. If you have then go with what Mike said to do.
Robert Horton
Nov 06, 2011 | Intertherm P3RA-048K Air Conditioner
We modular home in 2008 with a coleman furance model number DGAA090BDTB we have had nothing but trouble with the furance, the latest thing we found out the heat exchanger was cracking. We have had...
if the heater is a 2008 also then there should be a warranty still on the heat exchangers, i have installed modular units such as coleman ,intertherm, and nordyne common modular home units inthe past and at minimum the heat exchanger should have a manufacture warranty of at least 10 years on it... and up to 20 on the heat exchanger not exactly sure what the warranty is on this but can guarentee it should have at least a 10 year warranty...call manufacture with your model and serial number and they can give you warranty...then get a reputable company out to do the repairs...good luck to you that really stinks
Jan 08, 2011 | Coleman Heating & Cooling
I have a unit with a burnt transformer the original transformer has a red blue black on one side and a black with white stripes yellow and red on the other while the replacement has a green and red on one...
Hi, I have a suggestion here that might help. Contact the manufacturer to get an exact replacement sent to you. The manufacturer is Nordyne. Nordyne makes the same unit and private labels it for other companies, like Sears, Westinghouse, Intertherm, etc. Without out the correct color codes identifying the correct secondary (24Volt ) labeling of the wires the colors are meaningless. The colors of the original transformer wires are coded for the original Air Conditioning diagram that was packaged with it. The only standard coloring found on any transformer is for the primary side. i.e. 120 Volts 60 Hz Alternating Current. Those colors are Black for Hot and White for Neutral (or return).
If you get the transformer from Nordyne or a distributed for their products, Installing the new one will be very easy.
Here is the link to Nordyne
http://www.nordyne.com/web/ContactUs.aspx
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Intertherm P3RC-030K Air Conditioner
My nordyne gas furnace has a terrible odor coming from it. It is not natural gas. It is really bad when the heat is coming through the heat vents and into my home, and it smells putrid and disgusting.
Perhaps a small animal, bird, etc, maybe has fallen into the burners or close by, this often happens you need to have a look for any ...Umm .. foreign matter, in or around your unit, and remove it. There is a product called "Nil-Odor" this removes and neutralise's bad smells.
Mar 02, 2010 | Heating & Cooling
I am installing a brand new nordyne furance I am not getting power to the 24v transformer the 240 wires going to the transformer are connected to the same leg. What leg is the wires suppose to be connected...
The have to be connected to both legs of the 240 volts, one wire on each leg. You have to have 240 volts going to the high voltage side of transformer.
Feb 21, 2010 | Heating & Cooling
Does the Nordyne gas heater have a pilot light 903046 G6RC080C-16B If so, its out, How do you re light it with out calling someone to come out and do it. I don't see Nordyne Listed on the Heater Drop down?
The easiest way to really know is to open up the unit and find the gas valve. If it has a round knob that has "On", "Off" and "Pilot" stamped on it , then yes it has a pilot. If it just has an "on" and "off" switch, then it it has electronic ignition and the glow bar may be burnt out. Hope this helps.
Jan 18, 2010 | Heating & Cooling
Furance Nordyne E!EB-015HA
If the transformer is you must have a low voltage short.
does your transformer have a trip switch that you can reset?
You could try to use a hair drier and dry out any water residu in the compartment. but my guess is you have a low voltage short.
May 18, 2008 | Heating & Cooling
Heating & Cooling Logo
297 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
