Question about Scunci 52001 Handheld Steam Vacuum
Steam will not eject
Can not get steam to come out nozzle on steam cleaner
  • 6 more comments
  • Anonymous May 21, 2008
    same problem steam will not come out of steamer
  • red dance Jun 15, 2008
    My scunci steamer will not eject steam either.I have replaced the little red rubber o-ring.I have pushed a fine gauge wire into the nozzle.I have filled it with white vinegar and turned it up side down to soak for 2 days.I have filled it with water and swirled it vigarously,and repeated this step 5 or 6 times. It still does not work.The thing is it was working last year when I put it up.
    You can hear it boiling up inside but when you press the trigger nothing happens.Any help would be greatly appreciated .
    Thanks
  • rox822 Jul 04, 2008
    Same thing....it sounds like it's "steaming" in there, but it only sputters a bit when I push the "STEAM" button :-(
  • Anonymous Jul 21, 2008
    no steam
  • Anonymous Jul 24, 2008
    steam doesn't come out
  • Anonymous Jul 25, 2008
    I was hoping to find an answer to the problem. Seems we all have the same problem but, no answer. I slowly opened the top and steam came out. Press the trigger nothing happens.
  • eveannw1 Aug 21, 2008
    can't get steam to come out - but i did misplace the #7 nozzle at the end of the wand - does that need to be in to have the steam come out?
    I put the brush on and again nothing happened?
  • Maureen fanning May 06, 2013
    Same issue for me but I don't have a red o-ring
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Posted on Sep 10, 2008
I had the same problem and discovered that the plunger was not depressing due to a long period of use . I resolved it by taking the plastic casing off the top removed the plastic nozel from the valve housing and got a pair of chanel locks opened them wide enfough to go from the front of the valve housing to the back where the brass plunger sticks out and applied pressure to the plunger untill it finaly depressed as it would normaly. The plastic trigger just doesemt apply the kind of pressure needed when the plunger gets stuck like that. I think that might help you all sound like you have the same problem ie steamer gets hot but no steam comes out. KP
Posted on Aug 04, 2008
My unit is almost brand new - I only used it one time and the steam does not come out - thank you
Posted on Aug 21, 2008
Why is there no steam coming out of the nozzle?
Lois, is this a carpet cleaner or vacuum? If a carpet cleaner I have found that the hoses that deliver the solution to the carpet will become plugged at the nozzle. These can usually be cleaned with warm water. I would have to have more info as to make and type of unit to answer more. Viking.
Mar 30, 2016 | Vacuums
Can the nozzle get blocked and affect the pressure of the steam
Yes particularly if you use hard water (high in mineral content)
Aug 09, 2014 | Euro-Pro Steam Penguin Hard Surface Steam...
Simac evt 100 steam cleaner
Try taking the steam head apart and cleaning. If difficult to remove, fill a basin with white vinegar & a small amount of water and let it soak to remove the built up deposits in the system. Remember to only use distilled water when steaming to avoid build up.
Mar 30, 2014 | Vacuums
Ep93-11 steam cleaner replacement nozzles
please go to http://www.eureka.com/en-US/Customer-Service/Videos/
and proceed with common sense for troubleshooting and replacelmente nozzles.
God bless you
Jul 15, 2012 | Euro-Pro EP93 Steam Vacuum
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
We have a Magimix M 200 Purchased at John Lewis Registration No: 278739 approx Dec 2008. We have not got the purchase receipt. The nozzle for frothing up the milk is not working at all so we are unable to...
There might be a blockage in the steam tube or the frothing nozzle itself. Make sure the nozzle is clean and try inserting a pipe cleaner gently into the steam tube to clear any blockage that may be preventing steam from passing through.
Jun 30, 2011 | Vacuums
How to remove hood from hoover steam cleaner deluxe I can not find how to remove hood its on top of nose of steam cleaner
Hi Lisa,
Do you need to clean the nozzle or do you need to do repairs inside? You only remove the hood to do repairs. For cleaning the nozzle, refer to your owner's manual as to what to do after you finish cleaning. There is a description for how to clean the nozzle.
If you need to do repair, please reply back. Thanks,
Handie Andie
Apr 24, 2011 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Will not dispense water how do I trouble shoot bissell proheat steam carpet cleaner
Listen to see if you can hear pump run when pressing button, if the pump does run, than either you have a clogged nozzle or screen in water fill compartment.
Jun 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Scunci 52001 Handheld Steam Vacuum Logo
548 people viewed this question
Top Scunci Vacuums Experts
Roger Potts
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
