Question about Ryobi 26CC, 22 In. Hedge Trimmer
My hedger turns off when I turn it side-ways to
My hedger turns off when I turn it side-ways to cut my bushes
  • 63 Answers
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Posted on Jul 24, 2010
Bush led tv no power
You can use inverter
Apr 15, 2016 | Bush Televison & Video
Should there be any play in the frame mount bushings on the lower control arm or the rack and pinion frame mount bushing?
The control arm will move some, the bushings are rubber. Made to do that so the ride isn't like being in a tank. The rack only has one bushing, on the passenger side. If your talking about the bar behind the rack. It is called a sway bay. It has two frame bushings. If the sway bar is moving up and down 1/2 inch, the bushing are bad. There should be some movement, but 1/2 inch is excessive. Again they are rubber. Any thing rubber is going to have movement. But should be sloppy.
Mar 23, 2015 | 2006 Chevrolet Silverado 1500 2WD
When is the time to winterize rose bushes and how do I do this
I don't like to cut them all the way to the ground I keep them about thigh height. Mix up a bucket of mild bleach solution to dip your clippers in. Wearing gloves, locate a healthy leaf and cut just above that point. Dip clippers in bleach solution between each cutting to avoid transferring any nasties.
Finally using white glue seal the cut tips. Best time to do this is well before the first frost in autumn.
Oct 09, 2014 | Bon-Ton Nearly Natural Rose Bush with Vase...
Is there a special tool or technique for removing the main bearing on the flywheel side of a horizontal shaft 80202 0594-01 74100801 Briggs and Stratton (B&S) engine? B & S bearing removal tool...
what do you have a bush or a bearing as they are different items
if it is a bush ,use a hacksaw blade and carefully cut a slot in the bush then use a small chisel and fold the bush inwards until it slips out
if it is a bearing you can get a bearing puller that has two arms with half balls on the ends
you drill out the cage then insert the arms in between the balls an by turning they become jammed in the race grooves allowing the bearing to be pulled from the housing and shaft
May 24, 2017 | Sport & Outdoor - Others
Hedger wont run unless it has choke on
Sounds like the carb is lean. Back out the adjustments 1 quarter turn and work from there. Also make sure air filter is clean.That should get ya going.
Dec 20, 2010 | kawasaki Kht600d Gas Hedge Clipper Trimmer
How to replace a sway bar on a 1997 pontiac grand prix se 3.8
Tools needed - Wrenches 15mm, 13MM, 18MM. Sockets : 15MM shallow, 18MM deep, Hammer, Wire brush, Grease.
Jack the car up and put it on jack stands, this can be a little difficult if you live in the rust belt like I do, where the pinch strip is almost rotted away. Then put the jack under the front support for safety. Pull both front wheels 3/4 " to get plastic lug covers off, and 3/4" (or 19MM) to get the lugs off. now take your wire brush and clean the tie rod bolts throughly, until they are shiney clean and use the 18mm to back the nuts off, if they start to spin, put it back on and clean some more. If no matter what you do the ball joint spins in the tie rod, cut the ball joint off of it (I used a angle grinder with a wheel) and break the jam nut loose then count the threads to keep your alignment straight. If you get it off with out cutting the end its much easier. If you managed to get the joints off - if they are original they should lift right off - maybe a few taps of the hammer and they come right up, if they have grease fittings you may need a pickle fork to seperate the joint from the spindle.
Now if you got the kit I suggested it comes with links, so you can cut the old ones off, just because its a pain to try and pull them apart once they've been on as long as the car's been in service. Again Cut off wheel, sawzall maybe, torch only if you really know what you're doing because its close to the CV joint and ABS wires. If you don't have acces to any of this stuff you can try and break the bolt free and it might snap or just spin off. It's 13MM (might be 14, I did mine yesterday)- cutting it off is deffinately the way to go. You can use the hammer to pop the bolt back through the hole in the lower a frame, it takes a little work to get it to pop out because the rubber bushings weld themselves to the bolt.
Now you can get to the fun part, getting the sway bar hold down bolts out. They are 15 MM, you can use the shallow socker for three out of four bolts. All but the drivers side rear bolt. These will fight all the way out so a little PB blaster penetrating oil helps. but it is slow going. The last one, is a real problem - I used a 15mm box end up side down so it I could work it back and forth and it took 10 minutes but I got it out without dropping the sub frame. If you can get the hold downs off the bar it will make removal easier but if you slowly and gently snake it by you can get it out. no need to remove brake calipers or rotors or anything else.
Installation is the oposite of removal with a few tips:
Clean the hold down bolts with a wire brush until they shine, then coat them with antisieze. Then clean the subframe where the hold downs mount with break clean, finally thread the bolts back in the holes to make sure they thread in clean. This helps with cross threading problems that are common on these jobs.
Grease all of the bushings inside and out before installing them. it will eliminate squeaks. Push the bar in first and then put the hold downs on when it is in the car. it makes life so much easier.
Now that you have your hold downs in place thread the bolts down- you have to force the bracket down over the bushing to get enough so you can get some threads on the bolts. Before you put a wrench on it make sure you get at least a couple of threads into it. use the wrench for more feel, if it binds up at all stop and go back to make sure everything is right. When you have all four bolts caught stop and go onto the links.
Each link should have the bolt head on the bottom and then go like this: I greased each poly bushing with all purpose grease while putting it together and then wiped off the excess when I was done.
Bolt--Washer with cup facing up - Rubber bushing with flat side down---Lower A frame---Bushing Flat side UP----Washer with cup side DOWN----Metal bushing---Washer with Cup Up----Bushing with Flat side down----Sway bar-----Bushing flat side UP-----Washer with cup DOWN---Lock nut.
Both sides are like this, and then once you have them together go back and tighten up the hold downs. Go back and forth on each bolt in the hold down to tighten them evenly all the way down. Then tighten the links until you can just turn the bushings by hand. If you greased them, it will be difficult - but use a paper towel and you'll be able to feel it. Do not over tighten these until they buldge out, it can wreck the bar.
Once you have everything back together and tight, go back and check it all again. Then put the wheels back on it and take it for a test ride, it should feel great.
Oct 27, 2010 | Pontiac Grand Prix Cars & Trucks
Can I get my Ryobi Hedgetrimmer blades sharpened or replaced ? Its only 2 years old and blunt already, it struggles to cut conifer and tears rather than cuts. I am not impressed.
If the blade set is bolted together, then a local repair shop should be able to sharpen them. Look for a shop that works on Echo or Stihl hedgers, as they can be sharpened. If the blade set is riveted together, then it must be replaced as a unit. You did not list the model or item number for your hedger, but try www.ereplacementparts.com or www.ordertree.com . Both sites will allow you to type in your model or item number to look up all the available parts.
Sep 08, 2010 | Ryobi 18V Hedge Trimmer
I have a '99 Explorer XLT AWD that I just had the ball joints (uppers and lowers), shocks, new tires and front end alignment all replaced. I still hear a knock that sounds like the ball joints. I took it...
Nice advice from the "mechanics"! Jeez....okay, wheel...here are a few things to look at:
Namely, check the tie rods...the ball joints, make sure they got greased. Sounds like you have a "joint" problem. Something is not lubed properly.
Is this noticeable in a quick/fast turn and, can you hear it in a slow turn maxing out your turning raduis?
Mar 17, 2009 | 1999 Ford Explorer
Repace bushings
i believe you are referring to the constant velocity joints (CV joints)
they aren't that hard to replace. but somewhat involved.
Mar 13, 2009 | 2002 Honda Civic
2002 clunking problm
Check the macpherson struts to ensure they are not loose.  One way to check is visually in the engine compartment.  Check the top of the struts to ensure the nuts are not loose.  Another is to raise the side of the van where you hear the clunk.  Raise it so the wheel is off the ground.  Grasp and shake the strut to see if it is loose.  The struts should not be loose, but you never know.  As the strut is certainly ivnolved in bumps and rotates when the wheel turns, I would check there since you have already explored the bushings and links.
Jan 10, 2009 | 2003 Dodge Caravan
Ryobi 26CC, 22 In. Hedge Trimmer Logo
232 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
