Question about Dell Inspiron 6000 Notebook
Bluetooth technology. i want to know which internal card with bluetooth wireless technology is compatible with my inspiron 6000?
  • 156 Answers
Inspiron 6000 is compatible with Dell Wireless 350 Bluetooth Internal Module.
Check the link below for location, information and illustration
Posted on Apr 19, 2008
Cant find where to install a wireless card internally to my dell inspiron 2600
You can't install any cards internally as there isn't any room inside. If you want to add wireless capability you'll need a USB wireless adapter which you just plug in to one of the USB ports. This computer also has PCMCIA (card-bus) slots, but that's older technology. USB adapters are much easier to find.
Jul 31, 2011 | Dell Inspiron 2600 Notebook
I have a inspiron 1545 i want to ask if it have a blutooth
Wi-Fi Options:
Dell Wireless 1397 802.11g Mini-Card
Dell Wireless 1515 Wireless-N Mini-Card
Intel® Next-Gen Wireless-N Mini-card
Bluetooth Options:
Dell Wireless 365 Bluetooth® Internal (2.0) mini-card
You'll need the mini-card option.
Oct 31, 2010 | Dell Inspiron 1545 Notebook
How do i switch on the wifi in my dell inspiron 6400? The Fn + F2 command is switching on the bluetooth only
You can turn on/off Bluetooth and Wireless using the Fnand F2 key.
To enable or disable wireless networking, press <Fn><F2>.
Turns on when a card with Bluetooth® wireless
technology is enabled.
NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information,
see the documentation that came with your card.
To turn off only the Bluetooth wireless technology
functionality, right-click the
area and click Disable Bluetooth Radio.
To quickly enable or disable all wireless devices, press
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
Jun 28, 2010 | Dell Inspiron 6400 Notebook
Is it possible that my Dell Inspiron wireless card ( with Blurtooth ) is slowing my wireless broadband by approx 50% from an ethernet connection
With regard to your inspiron 6000 wireless, I believe that the wireless card included is a b/g type. This means that the maximum speed that you could get to a wireless connection is actually 56Mbps which is really around 50% of the normal ethernet connection which is 100Mbps. If you would like to increase the speed of your wireless what you need is to upgrade that to a b/g/n type which goes up to 100Mbps also with increase in distance. Also you have to make sure that the wireless access point or router also has a N-type wireless connectivity. Even if you have a N-type wireless card on your laptop, if the router is only up to G then it will still connect just up to 56Mbps.
Now, with regard to your bluetooth connection interfering with your wireless, You do not have to worry, both these devices connect at a different frequency. So they would not interfere with each other.
Apr 29, 2010 | Dell Inspiron 6000 Notebook
Headphone jack loose?broken?
You need a new one not worth fixing
how old is it when did it stop working
if you just bought it then
you need to return it and have it exchanged
there obviuosly is a defect.
Feb 12, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Internal Wireless card will not activate
Most likely you need to install the driver for the NIC card. Go to Device Manger under System Properties and see if the Wireless NIC is showing a driver error. If so right click, select Update Driver and navigate the the file on the CD. Once the driver is installed if should function normally.
Dec 23, 2008 | Dell Inspiron 6000 Notebook
Wireless internet problem
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
May 29, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
187 people viewed this question
Alun Cox
