Question about Sylvania DVC850C DVD Player/VCR
What is cst.in blinking light mean
My vcr/dvd palyer cuts off and then the cst.in light starts blinking.
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
I put a vhs tape in an the vcr turns off by it self a green light keeps flashing by where it says cst in. I have a Hitachi DVD/VCR COMBO DV-PF2U. I also can not get the tape out
Unplug the power supply for thirty seconds and plug back in, this will reset the processor and might eject the tape. If this fails the next step is remove the top of the combo unit this will give access to the vcr tape, if the tape is spewed in the machine and wrapped around the video head and other mechanical parts use scissors to cut the tape and carefully removing the particles, press power to eject the tape for normal operation. However! if the vcr tape is okay, there may be a loading problem, broken drive belt, bad idler assembly to name a few, this is where a technician will be needed but may not justify cost.
Jan 23, 2011 | Hitachi DV-PF2U DVD Player/VCR
When we turn the power on iit only stays on a few seconds then turns off with the cst.in light flashing.. what does this mean and what can we do to fix it?? tks
I had the same problem. We watched a DVD, and the unit worked fine. We went out for ice cream, came back, and decided to watch a VHS. Instead of taking the VHS, the CST.IN light flashed and the unit cut off after a few seconds. We didn't have a VHS in the unit at the time. After cutting the unit back on several times without success, I looked online for solutions. One person said to hit 'eject' 5 times in a row, but that didn't work for my unit. Someone else said there was a lever inside near the power button that ejected the VHS, so I checked that out next. I washed and dryed my hands well, and used my finger to jiggle the white lever. Then I saw that the tray that the VHS sits on wasn't all the way forward, so I gently pulled and pushed it. I'm not sure which of the two actions worked, but my light is now a steady green and my unit is working fine now. I am so glad because we've had this unit for almost 10 years now, and I really didn't want to have to buy a new one! Good luck!
Jan 17, 2011 | Emerson EWD2202 DVD Player/VCR
The cst.in function on my dvd/vcr is blinking and because of it, i can't work my dvd/vcr. What can i do to fix the problem?
Jan 16, 2011 | Emerson EWD2202 DVD Player/VCR
Can't set up a magnavox ZV457MG9
What it really means is set your tv to the channel that displays the VCR/DVD palyer
Jan 24, 2009 | Toshiba DVR660 DVD Recorder/VCR
CST In light is flashing green
I had the same problem. Aren't three-year-olds great? Mine had jammed several clothing tags into the VCR slot. Clearing them out didn't solve the problem, but I then took the outer case off (with power disconnected of course) and verified that there was no physical damage to the tape heads and that everything internally was clear. I put the case back on, and everything's back to normal.
Jan 06, 2009 | Sylvania SSD803 DVD Player/VCR
Help
I fix these all the time, change end sensors and Infra red Diode. Do not attempt unless you Know how ! Diode is under loading deck. Sorry if you are a novice bring to shop! Sorry It is easy only if you know what your doing remember change center IR sensor ( center diode on PC board. Also end sensors (2) one on left one on right side. Do not attemrt if you dont understand ! www.Irionstvshop.com Hope this helps.
Mar 03, 2008 | Philips Magnavox DVD/VCR Dual Player
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Green light blinks and player will not play dvd or vcr
take it to any repair shop and have them llik it over. It probaly has something stuck in the cassette area. th repair may cost $20 to $50, most of that is what the public calls a "walk in the door fee." If your comfortable doing it yourself just take the lid off and remove whatever looks like it doesn't belong there, like pet hair or something a child could have stuck there, ie a toy or a pen. Hope this helps.
Nov 24, 2007 | Emerson EWD2202 DVD Player/VCR
Sylvania DVC850C DVD Player/VCR Logo
1,845 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
