Question about Singer Sewing Machines
I have a singer 237 and the bobbin thread gathers
I have a singer 237 and the bobbin thread keeps gatering up underneath and it wont sew
  • Anonymous Mar 24, 2014
    Thread gathering underneath
  • 980 Answers
Nice solid machine that one, top tension on 4 or 5, make sure the bobbin turns anti clockwise in the bobbin case, if the thread is pulling out too tight slacken the screw on the bobbin case ant clockwise about a quarter of a turn at a time and test, you should only just be able to pull the thread through with slight resistence
Posted on Jul 14, 2010
I have a singer 201 knee control and I love it until today.
try these suggestions
rethread the machine top and bobbin, using every thread guide
try a new needle--one for the fabric being sewed--make sure the needle is inserted correctly into the needle holder
make sure the thread does not come off the thread take up lever
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
Oct 29, 2013 | Singer Sewing Machines
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
My singer model 237 makes a stitch that doesn't look right. The bottom thread is just goes through the top thread loops under the material
Hi, if stitches are off, there is a problem with balance between the upper and lower stitch adjustments. You have to tweak these. Also, make sure there is no lint in the bobbin case area or under the feeddogs. Here is an excellent blog for 237 Fashion Mate owners. You are lucky to have one of these from the 1960's. http://blog.sew-classic.com/2010/02/02/singer-237-fashion-mate-sewing-machine-reveiw.aspx
Happy Sewing!
Jul 17, 2011 | Singer Sewing Machines
My machine gathers thread in the bobbin and then the thread breaks off.
check the needle to see if it's damaged
some sewing machines gather thread in the bobbin area when the thread come off the thread take up lever
check the bobbin & bobbin area for burrs
Sep 23, 2010 | Singer Sewing Machines
SINGER CURVY: It jammed while sewing felt. Taking apart the bobbin area, I can see that the needle hits the bottom of the "floor". The bobbin is not catching or moving.
I think that your should try a new needle, it may be bent or have burr on it. It problem persists call Singer at 1-800-4singer, good luck
Sep 12, 2010 | Singer Curvy 8770 Electronic Sewing...
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
My singer 533 machine keeps bunching up with
Top tension about 4 or 5, make sure the bobbin turns anti clockwise, make sure you only use a mercerised thread no thicker than a number 40 and the bobbin thread should pull through with slight resistence only.
Oct 27, 2009 | Singer Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Sewing Machines Logo
545 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
