Locked channels and No remote for Citizen (JCTV 1592)
TV only gets channel 2 then goes to 18 to 36..I need code to program a remote inorder to work TV...Can you help?
I pressed some key on my remote accidently and thereon i have not been able to move to any other channel except adjusting the volume in this one...pls suggest...I do not know if this got locked..
Posted on Apr 23, 2008
I have a citizen television & the code is not in the list to program the remote, i can't get the remote to do anything. Is there a code for a citizen tv?
Hello
Try a code search method. Sometimes it may halp you.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 23, 2011 | Sony RMEZ4 Remote Control
My tv is locked how do i unlock it
Turn the TV on, hold the display button on the remote until the screen goes black. Turn off the TV and back on and it should work. Hope this helps! =]
Mar 03, 2011 | Jensen Q2749J 27" TV
I have a citizen TV - model #JCTV 32428. I have the remote, however can't get it to program for cable. When i bring up the menu & use the remote to navigate it won't let me into the TV Catv category....
I can help you troubleshoot your TV.
I am having a little difficulty sourcing information about your model though, is it possible I haven't got the make and model correct?
You are having trouble with a Citizen brand, model JCTV 32428 or maybe 3242A?
And just so I understand your problem clearly, you have the remote for the TV, and no cable box is involved, but the TV itself wont let you into its on TV cable tv setup menus? Is it the case that you would like your TV to autotune your cable TV channels, because you cant access them? Even when you simply enter a number like 31 in?
(Because sometime TVs make you choose between an input source being Antenna or Cable, and if you choose Antenna, you are stuck with a limited amount of channels, even though the cable carries so many more.)
Regarding closed captioning, are you also looking to have the audio from programs written on the screen with the closed captioning system? Or did you mention these button to help me identify your set?
Please forgive my many qualifying questions; I would only like to understand fully.
Also, even if I can't identify your exact set and provide a manual for you, I can recommend to you that in my experience, when a TV wont let me access cable channels and options, it is because somewhere in the setup I have selected Antenna as an input source. This is the only restrictive selection I can think of, given what I know of your problem so far.
I hope that helps; do post back if I have my model numbers incorrect.
May 07, 2010 | Televison & Video
I require the tv universal remote code to program a Citizen TV model JCTV 3082 serial V 43535298
i cant give u the exact one ull have togo thru these and find the one that works but here nthey are 0002 0502, 0906, 0112, 0512, 0520, 0115, 0701, 0402, 0805, 0407 one of these 4 digit codes should work just keep tryin them until u find the right one hope this helps
Feb 24, 2010 | Jensen JR300 Remote Control
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
How can i program my rc16 direc tv remote control to my philips tv
1.Press menu on your remote and then go to settings and press select on setup.
2.Go to remote and then go to reset remote.
3.Press and hold MUTE and SELECT until the light above the mode on tv switch on the remote flashes twice.
4.Enter the code using the numbers on your tv.
5.you have cleared AV1,AV2 and tv modes.Move the switch back to DIRECTV;press select on done.
Jul 10, 2008 | Directv RC23 Remote Control
Bigmatters universal jumbo remote ero4307j
manual de codigos del control bigmatters jumbo universal mod ero4307j
Jul 05, 2008 | Televison & Video
Code for RCA remode
This is all I could find.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 21, 2008 | RCA Universal Remote Control
Help
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
May 18, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
276 people viewed this question
Top Televison & Video Experts
