Question about OKI B4400 Laser Printer
Oki b4400 will print one copy then goes offline. Have to press online button for it to print again. Triangle light flashing quickly also. Anything i can do to rectify?
Soulvisitor
  • 1113 Answers
SOURCE: Have to put printer "online" after every page
Tec says - what sort of blink ??? blinking error light on your printer indicates many things besides jam and there are 5 types of blinks too ( odds are wants toner)
Here is your user manual that explains
http://www.oki.co.uk/binaryData/5929/B4K2uEN1.pdf
Original software includes a status monitor that reports printers errors on your computer screen
Posted on Nov 05, 2007
SOURCE: Okidata 5100C error code 490:MP tray empty
remove toner from your printer see any paper or wheels are jammed or loose...
Posted on May 28, 2008
  • 78 Answers
SOURCE: New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Posted on Oct 09, 2008
  • 43 Answers
SOURCE: Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Posted on Jan 17, 2009
SOURCE: Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
Posted on Jul 22, 2009
Printer still say need new drum even after being replaced
You need to reset the drum count. take the printer offline by pressing the online button. next scroll down on the menu button til you get to Maint. Menu. Next press Item+ button 2 times. LCD should say Drum count reset. next press select button.this will save the option. next press online button
to put the printer back online. you should be ok to print
Good Luck
Feb 23, 2011 | OKI B4350 Laser Printer
Paper needs to be a little lower when it prints, it;s printing too high
hi,press the offline button , manually turn the paper feed knob back a few clicks then press the set button and remember to switch the printer mode to online
hope this helps
Apr 28, 2010 | OKI MICROLINE 390 Turbo Matrix Printer
After every page I print, the green light goes out, and I have to press online to get it to continue printing.
Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
Cheers
Nov 15, 2009 | OKI B4600 Printer
I need to know OKIB4400 LASER PRINTER; TRIANGLE W/ EXCLAMMATION
This is an "Attention" indicator. Has a lot of meanings when blinking and all of them described in the user's guide. There is also Status Monitor Software that can be installed after the printer driver and which displays printer status on the PC's screen. Much more convenient way to get information from the printer than deciphering indication of the lamp in question.
Jun 05, 2009 | OKI B4400 Laser Printer
Printer is offline
Press the most left button at the printer front panel.
May 06, 2009 | OKI Pacemark 3410 Matrix Printer
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Mar 04, 2009 | OKI MICROLINE 590 Matrix Printer
Oct 07, 2008 | OKI B4400 Digital Mono Printer - Black
Oct 04, 2008 | OKI B4400 Laser Printer
get a new printer or go to a technition
Jul 11, 2007 | OKI B4250n Laser Printer
OKI B4400 Laser Printer Logo
148 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
