Question about Kenmore Elite 45986 Front Load Washer
Washer will not run, Kenmore HE2 Plus, Model# 47532601
Got an issue with my washer.
Her stats: Washer, Kenmore HE2 Plus, Model #: 110. 47532601, Series: HLT4114341
Issue:
First issue I had was when running a normal cycle it will go through the entire cycle and at the end display 1min remaining and never change from that state (door remains locked)
If I unplug and re-plug it in I have the following two things happen:
A) Same issue as before
B) Press power choose cycle, door locks then nothing just displays time remaining. If I press stop it beeps then all buttons on control panel are frozen (no response)
I ran the diagnostic test by following the steps in from the manual I found in the bottom front panel
And I was able to first see the following Error history F-24 (water temp sensor) and F-26 (door switch error)
Other notes:
I have pulled the release lever for the door and when the cycle starts I get the heavy solenoid click/slam.
When I first plug it in I get a slight little click in the control panel.
Re-ran diagnostic and I got a F-28
I pulled the top off and wiggled/disconnect/reconnect every connector I could reach (no change)
Put an ohm meter on the temp sensor and got a reading of 12.2 k-ohms which falls into the table in the maintenance manual.
The last thing I did was run the "Manual Diagnostic Test" as described below
The door locks then nothing every time I hit the button to move to the next step nothing happens, does this mean it is dieing in the first step, door lock?
Wondering if anyone has any thoughts?
Thanks!
F-24
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23°F to 217°F [-5°C to 103°C]) during the water-heating step of the WASH cycle.
NOTE: To find correct Ohm reading refer to the Water
Temperature Sensor section, page 10.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check the water temperature sensor and connection to it.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4.. Refer to the Water Temperature Sensor section, page 10.
F-26 (from manual link above)
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
F-28
SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU).
– Check connections of the CCU board within the housing.
– Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
MANUAL DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
-Close the door.
-Select any one key (except STOP) and follow the steps below, using the same key (remember the key):
Press/hold 4 sec’s.
Release for 4 sec’s.
Press/hold 4 sec’s.
Press/hold 4 sec’s.
Press/hold 4 sec’s., release
NOTES:
-Press the same key to advance to the next failure code.
-At the end of the procedure the program will loop back to the beginning. This is a continuous loop.
-To cancel out of the Manual Test Mode press STOP.
Exit Condition Control Action To be Checked
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
SOURCE:
Who makes Sears washers and dryers? Does Whirlpool make them
The model number on your washer or dryer (located on a nameplate around the door opening) should have a prefix code of "110". This number identifies the manufacturer as Whirlpool. If you need further assistance, please post back and let me know. I hope this helps you.
Oct 13, 2010 | Kenmore HE2 Plus Front Load Washer
I have a He2 plus model 110.47532601 with bad rear
Hello Rickgall1998,
If t is a rear bearing (no symptoms listed) I doubt at 3 years old the bearing can be bad! I can't help you but if it is the door seal or some other common part perhaps you can find it here;
Kenmore Washing Machine Model 110 47532601 11047532601 110 47532601 Parts
Without some symptoms being listed it is hard to assist you.
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore HE2 Plus Front Load Washer
No water run into the machine, kenmore front load washer
Is water turned on to machine don't laugh it has happened.
Check water valve if you know electricity you can hook 110 volts directly to the water valve and see if water will come out or check with an ohm meter.
Also be sure you have 110 volts to machine check first.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,177 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
