Question about Saeco Coffee Makers & Espresso Machines
Saeco syntia - error message 'problems with the water circuit'
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Posted on Jul 12, 2010
  • jbrightman57 Jun 26, 2011
    Its like a little "bomb" with a backward "S" to the right of it. I looked in the booklet and that's where it showed the symbol and said "Problem with water circuit".
I have a 6-month old Saeco Syntia coffee machine. The display reads "Problem with Water Circuit". Is this something I can fix myself? I've lost the store receipt. Thank you. Joanne
Posted on Jun 26, 2011
Saeco Syntia dumping dry ground coffee into dreg drawer without making espresso. **SOLVED** Follow up below.
First, I'm NOT a Saeco technician, But I have worked on similar machines. (I still have one in my garage along with other 'graveyard' coffee machines.) Check your warranty and call for service as there are no customer serviceable parts in this equipment.
*** the following is for information only ***
* I've taken these machines apart many times and found there are a lot of sensors in this unit. Many are very delicate and fault out easily. If you do locate the right sensor, you will still need to locate a replacement. Ordering parts can be a challenge as it must be the correct model (and serial number series). I found out the hard way that not all PC boards are the same as the change functions even in the same model.
* Okay looking around I came across a vid (link below) that shows in detail how to check all the functions of the model he has. You probably don't need to go through the descaling and other checks. The Bean grinder portion is very detailed and not for the faint of heart. But his instructions are clear and should be able to solve your problem. His "No Bean" error was caused by prolonged use without proper cleaning and someone spilt water into the bean cup long ago. I hope to try out his method soon as I never took apart the grinder section completely like he did. I only vacuumed the beans out.
Good luck (to all of us!)
Aloha, ukeboy57
https://www.bing.com/videos/search?q=Seaco+Syntia+no+beans&&view=detail&mid=7D35DEE54A6DBDC3688B7D35DEE54A6DBDC3688B&&FORM=VRDGAR
Feb 08, 2018 | Saeco Coffee Makers & Espresso Machines
I have a Saeco syntia which I usually add beans, but have ground coffee and am not sure how much to add
If it's an espresso machine, you can find a manual at link. Use the scoop provided with the machine and add 1 scoop, no more than 2 scoops.
Visit the support page for your Saeco Syntia Super automatic espresso...
Oct 07, 2017 | Saeco Coffee Makers & Espresso Machines
Syntia swims in water in dreger drawer
Syntia is not set to "3 beans" amount or beans used are too large to create enough grounds to make a full 9 grams for a good puck .
The finger guard does not allow enough beans to grind in the timing of the software , common problem.... until the finger guard openings are made bigger or ... the software is re-programmed
Mar 05, 2014 | Saeco Syntia Espresso Machine & Coffee...
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia leaking out the bottom
Over pressure valve is broken, near the water pump , stop using it and get it fixed , or you may damage your Computer board
Nov 08, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
Water tank parts for saeco syntia
Don't know where you are but www.dutchwest.co.uk in the UK supply the parts.
Mar 02, 2011 | Saeco Syntia Espresso Machine & Coffee...
Salton won't pump water
what kind of Saeco machines have you got?
It's a problem of syntia? could you explain me specifically what is the problem, so I could be helpful.
bye
F
Sep 15, 2010 | Saeco Coffee Makers & Espresso Machines
Open Questions:
Coffee Makers & Espresso Machines Logo
1,854 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
