Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Have a 16" Model 36 - need to replace clutch? How is this done?
    Brigadier General:
  • 4,088 Answers
Remove the muffler so that you can observe the piston position and turn the engine slowly until the exhaust port is just starting to open on the down-stroke. Stop at that point and fill the combustion chamber with starter or other fine cord to prevent the piston from rising much further. The clutch should now be able to be removed by rotating the internals CCW (left-hand threads). Don't try to use an impact wrench for this as it will cause the flywheel key to shear. If you are having problems getting the chain to move and there is no obvious mechanical damage with the clutch, try washing the clutch interior out with spray carburetor cleaner, let dry, re-assemble and test. Hope some of this helps!
Posted on Jul 11, 2010
I'm looking for an intall manual for an LG Gas Cook top Model # LCG3691ST, and a LG Fridge # LMX21984ST and a LG wall oven #LWS3081ST. Can you please help?
Hello Lola,
I understand that you need the installation documents for a few LG appliances you have. I would be glad to assit you in this endeavor.
LG Gas Cook Top LCG3691ST -
Product (36")
Width 36"
Height 3 34"
Depth 21 11/16"
Cutout (36")
Width 33 15/16"
Depth 19 11/16"
Minimum Spacing (30", 36") 1" Back, 11 13/16" Left, 11 13/16" Right
Net Weight 44lbs (30"), 50lbs (36")
LG Fridge LMX21984ST - http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LMX21984ST&matchedModelCode=1000004146&searchEngineModelCode=LMX21984ST&targetPage=support-product-profile&initialTab=documents
LG Wall Oven LWS3081ST - http://www.lg.com/us/appliances/pdf/LWS3081STss.pdf
The above gives you the need deminsions to install the units.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Kitchen Ranges
1994 husky model 36 air induction with 16 inch bar. not getting oil to chain & bar.can't find adjustment screw
The pump is not adjustable, it has either striped the nylon pump gear, or the filter in the tank is blocked, or there is a bad seal between the pump body and the delivery/pick up pipes, to get to the pump you need to remove the clutch and sprocket, the pump is then held on with a couple of cross head screws, there is a much improved seal for the pump part no. 545037101 this is well worth fitting, the pump is part no. 530014410.
May 09, 2011 | Garden
I have a clutch fan on the water pump how do you remove the clutch from the pump?
Need a 36 mm wrench or 1 7/16"
Put a pry bar across pulley bolts to keep
pump from turning, while you unscrew fan
Mar 18, 2011 | 1995 Dodge Dakota
Need to know how to remove nut on water pump to remove fan/ clutch. have wrenchs
That is about a 36 mm wrench,which is close to
1 7/16".
You will have to borrow one,then use a long pry bar to hold the
nuts on the pulley to pump,so it won't turn
The fan screws on normal direction, as I recall
Mar 06, 2011 | 1996 Dodge Ram 1500 Club Cab
Does this model support printing on 34" paper?
The printer will support the following media sizes:
Roll paper (width) -
ISO: A3, A2, A1, A0,
JIS: B2, B1,
ARCH: 24", 36"
Others: 10", 14", 16", 17"
Cut sheet -
ISO: A4, A3, A3+, A2, A1, A0, B4, B3, B2, B1,
DIN: C4, C3, C2, C1, C0, JIS: B4, B3, B2, B1,
ANSI: 8.5 x 11", 8.5 x 14", 11 x 17", 13 x 19", 17 x 22", 22 x 34", 28 x 40", 34 x 44",
ARCH: 9 x 12", 12 x 18", 18 x 24", 24 x 36", 26 x 38", 27 x 39", 30 x 42", 36 x 48",
Photo: 20 x 24", 18 x 22", 14 x 17", 12 x 16", 10 x 12", 10 x 15", 8 x 10", 16 x 20" (US Photo size), Poster: 20 x 30", 30 x 40"
Dec 16, 2010 | Canon imagePROGRAF IPF720 Printer
Need diagram for serpentine belt
Fig. 1: Exploded view of the belt drive fan assembly-1992 vehicle shown
To install:
1. Position the fan on the drive clutch. Install the bolt and washer assemblies, then tighten to 12-17 ft. lbs. (16-24 Nm).
2. Position the fan drive clutch, fan assembly and fan shroud, then bolt the fan and clutch assembly to the water pump hub. Install and tighten the clutch retaining bolt and water pump assemblies evenly and alternately to 15-22 ft. lbs. (20-30 Nm) for the 3.8L engine or to 36-47 ft. lbs. (48-65 Nm) for the 5.0L engine.
3. Install the fan belt. Align the fan shroud and adjust for equal fan-to-shroud radiator clearance but maintaining a minimum of 0.38 inch clearance to the fan tip on 5.0L engines.
4. Install and tighten the shroud retaining screws. On 5.0L engines, snap the air deflector assembly to the sub-frame cross brace.
Hope helps (remember to rate and comment this
Dec 03, 2010 | 1995 Ford Thunderbird
I need a serpentine belt diagram for a 1991 ford thunderbird v-8 5.0
To install:
Hope helps (remember to rate and comment this).
Oct 01, 2010 | Ford Thunderbird Cars & Trucks
Multiplication table
x 01 02 03 04 05 06 07 08 09 ...
01 01 02 03 04 05 06 07 08 09 ...
02 02 04 06 08 10 12 14 16 18 ...
03 03 06 09 12 15 18 21 24 27 ...
04 04 08 12 16 20 24 28 32 36 ...
05 05 10 15 20 25 30 35 40 45 ...
06 06 12 18 24 30 36 42 48 54 ...
07 07 14 21 28 35 42 49 56 63 ...
08 08 16 24 32 40 48 56 64 72 ...
09 09 18 27 36 45 54 63 72 81 ...
Jun 15, 2010 | Mathematical Technologies Inc. MTI Tristan...
I have a model 36 I am looking for an owners manual to replace and tension the chain correctly. Please advise. Thank you. Michael Edwards. michael.e@bancorleasing.com I am listing this as dictated by the...
You can obtain an owners manual from store.payloadz.com. they do manual's for almost every type of machine. hope this helps p.s the price for most of the manual's is only $8.99
May 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Pyramid 35 amp regulated power supply
Use specified power supply by the computer.
Feb 05, 2008 | Computers & Internet
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
52 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
