Question about Epson Perfection 1670 Flatbed Scanner
No image appears in preview or after scan using Epson Perfection 1670
I had exactly the same problem after moving my scanner to a new location, even though it was locked... it happened blank scanns, so I was about to go get my self a new scanner.
What I did was to get a cotton pad, put alot of alcohol on it and clean both sides of the connection usb cable in/out and then let it dry. Also I unistall all the epson scanner applications and reinstall with the new driver epson 12699.
It worked perfect, try it you have nothing to loose.
Posted on Oct 11, 2010
I unplugged my epson perfection 1670 scanner because my my mac said it was not connected--now when I scan something there is no image--just some lines--how do I correct this?
try uninstalling the drivers and then reinstalling them if it doesn't work you will need to replace the lamp in your scanner for information onthis go www.epson.co.uk/support
Jul 13, 2010 | Epson Perfection 1670 Flatbed Scanner
Scanner is not detecting images / photos to scan resulting in a blank preview
The image sensor may have gone bad. Try reinstalling the driver, if it does not work... It is time to get a new one (it is more expensive fixing a scanner than buying it brand new). Sorry. Good luck.
Jan 03, 2010 | Epson Perfection 1670 Flatbed Scanner
I keep getting an error that reads "unable to write to file". It was working fine and now I get that error about every 3rd scan.This is on an Epson Perfection 1670 scanner.
Just check if you have enough space where you are directing the scanning software to save the scanned images. You may be running short of disc space.
S. Mohan
Nov 04, 2009 | Epson Perfection 1670 Flatbed Scanner
We have plastic form to scan slides, no matter where we put it the preview on epson 1670. help
you will need to clarify your problem, that does not make sense.
make sure you have the proper slide adapter and check your twain settings for the right settings.
Nov 01, 2009 | Epson Perfection 1670 Flatbed Scanner
Epson scanner 1670 scans a blank page
I can not copy scanned pictures from my epson perfection 1670 scanner from windows xp. Everything works from taking the scan and putting into a folder to be copied. When I bring this folder up to copy a blank 4"x4" or so window shows. I've used this scanner for 2 years or more and have had no problems till now.
Mar 15, 2009 | Epson Perfection 1670 Flatbed Scanner
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
1670 no image scan
Same Problem (WinXP System). I found leaving it off when not using it fixes my problems. (Its like the scanner light overheats or overloads the light receptors and it just sees white from then on, no matter what you do on the pc side of things). Other problems while stumbling into this "fix" include WIA drivers loaded which will stop scanner working properly, and finally scanner drivers seemingly working when USB cable in connected to another port other than what it was installed on but no image is shown (Not 100% sure if it was same problem as detailed at top)
Feb 08, 2008 | Epson Perfection 1670 Flatbed Scanner
No picture in preview box
Here's what Epson tech support sent me about this problem:
Thank you for contacting the Epson Connection.
The error you are receiving may be from the twain driver but also the
Scanner itself. Please have your scanner checked with a technician. You
may
find the neares one by clicking on the link below.
http://www.epson.ca/cgi-bin/ceStore/support/SupportIndex.jsp?BV_UseBVCookie=yes
If you require further assistance with this particular issue, please
ensure
all of our previous correspondence is contained in your reply, so we
can
better track the history of this issue.
If you have a different issue, please submit another E-form via our
website
(http://www.epson.com), and we will respond in a timely manner. Thank
you
again for contacting Epson.
Patrick H
Epson Connection
Oct 06, 2007 | Epson Perfection 1670 Flatbed Scanner
Epson Perfection 1670 Flatbed Scanner Logo
241 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
