Question about Home
Removing old sink and need to turn off main water from road. need to make sure what the shut off valve looks like before i turn the water off and which way i need to turn to shut water off.
  • 760 Answers
So you have no shut off for whole house inside? Very unusual, but not impossible. Do you have a water meter pit at the curb? If so ilt's like a baby manhole.. Remove cover (probably 5 sided nut, use channelocks) on each side of the water meter or at least before the meter there will be a valve. It most likely is a ball or plug valve that you would turn 1/4 turn usually cockwise. If you dont have a meter pit you'd have a smaller cover and the valve will be quite a distance down, sometimes in water. You need a special long handle wrench for that. If you can't turn your water off your water utility should come turn it off for you so you can make repairs. They want to conserve water also
Posted on Jul 11, 2010
Where can I find the water valve shut-off for my kitchen sink
The sink usually doesn't have a shut off of it's own look on the side of your house ,the side closest to the meter & there should be a main water shut off valve for the house.
Jun 06, 2012 | Plumbing
Hot water wont stop running on hot water side
If the hot water side of the kitchen faucet will not shut off valve under the sink, dirt,rust,and/or scale could have been forced into the faucet along with the possibility of flux and some old rubber washer from the old valve. You will need to take the kitchen sink faucet apart and most likely only need to clean it out, looking for any little black,brown, or white pieces to remove. If cleaning does not work because you cannot get into an area of the cartridge, you will need to replace the carteidge and or rubber seals. Make sure to clean out the aerator on the end of the spout when completed also.
Sep 29, 2011 | Pioneer Plumbing
How do you shut off the water from the valve behind the toilet..i keep turning it but it doesnt appear that the water is turning off??? it just turns and turns??
It sounds like the valve is stuck and the valve handle is bad. All toy need to do is remove the screw from the valve handle, remove the handle, use a pair of water pump plyers to turn the valve. I would suggest that you replace the valve, to do this shut of the water main. remove the hose that goes to the toilet from the valve, remove the valve, ust Teflon tape and reinstall a new valve, reinstall the hose, Turn on the water main make sure the valve is on, check for leaks. Its really quite an easy job.
Jun 14, 2011 | Home
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
My dishes are still dirty after washing
There might be may reasons. Let me provide you with all the steps :-
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Oct 14, 2009 | Zanussi Dishwashers
How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
Sep 03, 2009 | Jado 827-850-144 Shogun Single Lever...
Water in washing machine from emptying sink.
A washing machine filling with water overnight or when not in use has two possible causes. Either the water is running into the washing machine from the sink ( If the drain hose is connected directly to the u-bend under the sink ) or one of the water valves isn't shutting off properly and water is dripping slowly but surely into the washing machine. The latter problem can take several hours before the water level rises high enough inside the washing machine to be visible.
It's easy to track down the cause of water entering the washing machine when not in use. If turning off the hot and cold water taps stops it, then it's one of the water valves not shutting off properly, and needs replacing. It's just a process of elimination to find out which one it is. If not, the water is likely to be coming from the sink (use above link). Sometimes by removing the soap dispenser drawer and carefully observing inside the soap dispenser you can clearly see water dripping in at regular intervals.
Blocked water valve filters: I've come across cases where a filter in the water valve has become caked in a brown sludgy mud-like substance due to disturbances in the plumbing. This could be because of work carried out on internal plumbing or even after workmen have turned the water off in the street to work on the water mains. After the water is turned back on, muddy or gritty water can enter the household pipework and when you use the washing machine it can draw this contaminated water into it.
In this scenario very fine grit or muck can get past the filter and stop it shutting off properly, or the filter is so blocked that water pressure to the valve is reduced enough to prevent the valve shutting off properly. Remove the water valve filter with some pliers and thoroughly clean it out. If the fault persists, replace the valve.
Important things to watch out for are -
  1. Washing machine water valves need a certain amount of water pressure to actually ensure the water is shut off properly. Therefore, if your water pressure is very low, it can seep in past the closed valve. This problem is less likely to suddenly appear unless your water pressure has suddenly dropped. It's more likely to be a problem with a new installation. ( Related: Low water pressure and washing machines )
  2. A faulty tap can mean that although you turn it off, the water supply isn't actually cut, so be careful of assuming if the fault still occurs, that you have definitely discounted the water valves. If unsure, you would have to disconnect the hot and cold fill hoses to ensure the water supply is properly cut when the taps are turned off. This problem is a lot more common with water taps that turn off with a red or blue plastic lever.
  3. If the washing machine has just been filling, you may get some dripping of water into the soap dispenser for a few minutes after. Don't mistake this for a valve not shutting off properly.
  4. If the water ever gets turned off while work is carried out on the water mains in the street or for major plumbing in your home, run lots of water in the house through taps at the sinks until it runs clear after the water is turned back on.
Faulty water valves should be replaced or there is risk of flooding.
Jan 11, 2009 | Washing Machines
Kitchen faucet Remove
Start by turning off the water supply, either by shutting off the main water supply to your house (probably located close to your water meter), or by closing the shutoff valves on the water supply lines to your faucet. Then, open the tap to allow the water to drain out of the lines and remove any water pressure. Next, use your adjustable wrench and disconnect the hot and cold water supply lines running to the faucet. If you're going to replace the lines, disconnect them at the shutoff valve, but if you're going to reuse the existing lines, do your disconnects at the base of the faucet itself. ow it's time to actually remove that old faucet. Faucets are attached in one of two ways. Bottom mounted faucets are removed from the top of the sink. To remove a bottom mount faucet, you need to take off the faucet handles and escutcheon to get to the nuts holding the faucet. Once the nuts are exposed, use your wrench to take them off. Top mounted faucets, unfortunately, are held in place by nuts located on the underside of the sink. You'll need to get under the sink to remove them, and space may be at a premium. If you're lucky, you'll be able to use your slip joint or locking pliers to loosen the nuts. However, if pipes are in the way, you'll need to use a basin wrench (a wrench specially designed to work in tight spaces where you don't have room to use an ordinary wrench or pliers). Once you've removed the nuts holding the faucet, just lift it up off the sink. If there is some caulking holding the base to the sink, slide the blade of a utility knife carefully around the faucet base to cut it loose. You'll need to remove any old caulking or "grunge" that may have built up around the old faucet. You can get silicon remover at your home store, and a mixture of vinegar and water or an orange cleaner will remove the grunge.
Aug 27, 2008 | Danze Fairmont Double Handle Roman Tub...
Home Logo
153 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
