Question about HP Computers & Internet
I have a hp computer and the hp model: 5187URF2+ P/N 5188-3573 REV 1.3 receiver connection box will not light up at all, can this be the cause for the computer turning on but not booting up? I need to know what to do. Thanks
    Champion:
  • 218 Answers
I hate these computers my freind and would as soon as i could replace the motherboard to save yourself a lot of trubbl;e hope this helps
Posted on Jul 12, 2010
    New Friend:
If your pc powers up but wont boot to post the first thing you want to do is listen for any beep codes and look up the beep codes for that pc or motherboard if you dont hear any beep codes next thing is to check that your internal cables arent loose and to make sure the ram cards are properly seated. Next check to make sure if your graphics is seated properly if your graphics card isnt built in. Make sure that the power cord is not plugged into the power supply before checking the connections...after you have checked that everything is seated properly plug the power back in and see if it boots, if it doesnt boot unplug the power again, remove the ram cards and install only one ram card into the first slot and them see if the pc will now boot, if it doesnt remove the ram card and try the next ram card and again see if the pc will boot, do this for each ram card. If it boots for all ram cards except one then you have a bad ram card install all ram cards except the one which did not boot, if none of the ram cards boot the pc youre down to a bad graphics card or a bad processor or bad motherboard
Posted on Dec 31, 2015
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
CAN START ENGINE EVERYTHING WORKS APART FROM REV COUNTER NEUTRAL LIGHT AND INDICATOR LIGHT ON REV COUNTER ?
Hi, Jeremy I would love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information. Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 26, 2015 | Motorcycles
How to fix hp pe1245 17-lcd color monitor
i have a hp monitor hp pavillion f1703 where is the plug in on the monitor? can not find one. is it hidden or does it not need one?
Feb 23, 2012 | HP Computers & Internet
Sling Box Pro - No network light, No light in logo, only power light on. Therefore won't connect to network. Was working fine. Tried reset button and also power off/on. Only the red power light is on.
roggey
If you are getting a light on the Sling Box indicating that it is connected and powered on, you may check your Internet connection to the receiver to make sure you are actually connected.
You can check you Internet connection on your receiver by pressing the Menu button on your remote. This will display the Main Menu on your TV screen. Press 6 (System Setup), 1 (Installation), and 9 (Broadband Setup). Once you are on the Broadband Setup screen, press 1 (Network Setup). An IP address should display on the Network Setup screen. You can also run a connection test on your receiver. If you continue to have problems connecting, you can give Sling Box a call to troubleshoot the Sling Box. Here is a link: http://support.slingbox.com/go/home. I hope this helps.
Ray Calo
DISH Network
Feb 07, 2011 | Sling Media The Slingbox Pro
Bestec power supply model ATX-300-12Z Rev BD green indicating light flashes on off when plugged in.
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Jan 06, 2011 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
The "wireless on" light will not go from red to blue
Try this :
1.Download the latest wireless driver for computer (7.20 REV:A, 2/20/09) - Might change depending on your CPU, (7.20 REV:A is for AMDs)
2.You will also need to download the latest Bios (F.42, 3/9/09)
3.Latest version of HP Wireless Assistant (3.00 REV:K, June 2009)
NOW YOUR READY TO START FIXING?????
INSTALL STEPS: You must use this order for an 100% fix
1.First flash your computer with the latest BIOS and if should restart after its complete.
2.Install the wireless driver
3.Install HP Wireless Assistant
4.Restart your computer
5.Flash Bios again
6FIX
Apr 20, 2010 | HP Compaq Presario V2000 Notebook
Activate (dv6)HP Pavilion bluetooth.
The Options tab in Bluetooth Devices provides options that control how devices discover and connect to your computer. The main option is Turn discovery on. This option lets devices discover your computer so that you can make a connection.
Other options on this tab include the following:
· Allow Bluetooth devices to connect to this computer
This check box controls whether any devices can connect to your computer. If this check box is cleared,
no devices can connect to your computer.
· Alert me when a new Bluetooth device wants to connect
This option controls whether you receive notification when a device tries to connect to your computer. If this check box is cleared, you do not receive notification.
Other options on the Options tab let you turn on or turn off the Bluetooth icon in the notification area and restore default settings.
Nov 11, 2009 | HP Pavilion dv6000z Notebook
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Dec 28, 2008 | Yamaha RX-V663 Receiver
Computers & Internet Logo
500 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
