Question about Maytag LAT3600A Top Load Washer
Maytag top load neptune washer error code od
I have a maytag neptune top load washer not sure of model has error code od. i tried opening the door like it says in the manual. it is a saftey feature. the lid must be opened before another cycle is started. I tried unplugging the whole machine but the error will not clear.now what
    Scholar:
  • 91 Answers
I own a maytag neptune, top load washer with electronic board or lcd screen, od code display, those are the door switches locates on the side of the door, the switches are electronic, an after opening the washer an opening the switches I discovered that the wire that sends the signal from the switches to the board were broken an rotted from the mold an soap that got accumulated in the switch, I took the switch an cleaned all the electric contacts, an stripped the wire back to were the wire was in good shape an re-solder the wire back to the switch, assembled back together an had the error went away ( no need to do anything else), the switches are attach to the machine with a 1/4 in screws , if you are not handy with soldering wires, you can order the part, ask for the lid switch give them your model number an I think they run about 75 dollars each, time to change em if ur a newbie, maybe an hour , I can do it in maybe 20 mins tops!
try it hope it works for you!,,,,,,
new washer 600
new parts 150
making a wife happy...............priceless!
good luck! let me know.
Posted on May 26, 2009
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytag neptune tl that comes up with an error code "od" Has anyone any idea what this is and how to fix it? Thanx Bruce
Open Door Error. - Problem with the door latch mechanism or sensor. For the od error, open the door and jiggle the locks.
It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened.
You might need something fairly long and thin such as jeweler's screw drivers
OD :The door has not been opened after two complete wash cycles. Door switch was not seen open since the last two final spins.
Here is a shop manual for your model.
Try to run the diagnostic mode, see manual. Or unplug for 5 minutes. Remember if this code reappears you may have a stuck or bad door latch.
if after running a diagnostic, and th latch is still reporting an error - it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune top load. I am getting an od code
Be sure to unplug the washer before attempting any troubleshooting. On the Maytag Neptune the "OP" code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
"od" = Door Open. Most likely a relay or wax motor in the door latch assy.
Jan 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Error Code "od" while trying to start machine
Could od mean overload? Reduce or actually weigh load and re-try
Apr 15, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LAT3600A Top Load Washer Logo
294 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
