Question about Fedders Y Chassis A6Y12F2A Air Conditioner
Fedders A6Y12F2A rev E not blowing cold air
I am having a problem w/ my model A6Y12F2A rev E air conditioner. It was working fine yesterday, and today when i turned it on the fan motors are working fine but it doesnt blow cold air. I hear an occasional buzz/humm like something is trying to kick on but it doesnt.
  • jeremy3ff Jul 14, 2010
    It seems to be the compressor that isnt kicking on. I can hear it buzzing like it wants to but no luck. any ideas what could be wrong or if it could be easily fixed
    President:
  • 4,070 Answers
Hi! YOu may have a refrigerant leakage. The compressor cant kick for it has a leak. You will need run a leaktest to find the leak. Its gotta be on the fittings somewhere. Once fix and loaded with refrigerant you'll be good. HOpe this helps and have a good one!
Posted on Jul 14, 2010
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link to diagnose what could be wrong with your air conditioner…
http://www.inspectapedia.com/aircond/aircond15e.htm
http://toad.net/~jsmeenen/compressor.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 11, 2010
I have a Fedders Window Air conditioner, model A2008F2BG. It was working great until today. Now it comes on but the fan wont blow much air. Any ideas?
I believe that is an older window unit. I don't know how difficult it is to get to the fan, but I would check to see if it can be cleaned, then see if there is any insulation or anything that is blocking air flow. I am assuming the filter is clean?
Aug 01, 2016 | Fedders Heating & Cooling
What is the code for EE on display
EE is the thermistor is bad or pulled off at the terminals on the circuit board, more often it means it is defective and requires replacement.
Jun 06, 2014 | Fedders Y Chassis A6Y12F2A Air Conditioner
How do i add freon to my fredders service # a6y12f2a-a
Hello, wimdow air conditioners do not come with service acsess fittings, so you must add a piercing valve to the unit to add refrigerant.
Jul 16, 2012 | Fedders AEQ07FBG Air Conditioner
My fan is screeching but the compressor is blowing out cold air
sounds like you have bearings on there way out in the fan motor
May 21, 2012 | Fedders D Chassis A6D24E7A Air Conditioner
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
Where to connect three wires
You should have:
one wire from the compressor that will hook to "HERM".
one wire from the fan motor that will hook to "FAN"
one wire from the relay ("hot" wire") will hook to "C".
Apr 14, 2010 | Fedders Y Chassis A6Y12F2A Air Conditioner
Fedders
if it is blowing at all, this narrows the field to a compressor issue, if the compressor is coming on, but not blowing cold it could be that the coils are dirty and need to be cleaned. They can appear clean from the outdside and be dirty on the inside.
Jul 19, 2009 | Fedders AEQ07FBG Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Fedders Y Chassis A6Y12F2A Air Conditioner Logo
138 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
