Question about Pool & Spa
Low pressure of 5 on our pool pump. Replaced sand, replaced filter O ring, no air leaks (no bubbles, no air in pump), and no clog in the filter line (bought a device to clear out any potential clogs, and all is good). The pool company said our motor was fine, impeller included. The new cleaner I bought won't climb the walls more than 2 feet and algae is growing on them. (This cleaner should climb the walls). Could it be a 1 HP motor is too small? Pool is about 22,000 gallons. Our old cleaner used to climb the walls a long time ago but we have a different motor since then, have no idea if the size is different. We have the ancient Hayward type motor unit and filter. Don't know where to go from here and algae treatment is expensive (refilled pool water last Oct). HELP PLEASE! :-)
  • 2 more comments
  • mywave Jul 11, 2010
    We took the motor off to see if the impeller needed to be replaced/clogged and the pool guys said it was fine. However we did not take the impeller off the motor. Would the clogged side be the grooved side? that was fine, no clogs.
    Also no clog between filter and impeller
  • mywave Jul 12, 2010
    I would say I'm 90% sure there is no obstruction. We do not have any problems filtering small palm seed things that wind up in the basket. I would imagine those would get stuck in any clog. We ran the pressure attachment from the hose both directions from the skimmer and from the filter. The water went through fine and there was no 'back jerk' like the clerk had suggested if there was a clog.
    I do have a tiny bit of air in the pump I noticed, but it is a very small amount. (After running the pool several hours, it takes about a couple of seconds to release the air). What is the best way to check for air leaks? thanks!
  • mywave Jul 20, 2010
    My problem has more/less been fixed. My pressure is still low, but I was missing a plug in the skimmer line for the maindrain. Now, I do get more suction to the vacuum. thanks!
My neighbor had this same problem. His problem turned out to be that his 2 jets on the side of the pool had.... had the eyeballs removed unscrewed & lost ( most likely by kids metalling w/ them) This caused his entire piping system to not build up the proper back pressure it needed to drive his polaris. A simple trick to try would be to turn on your pumps & put you hand over one or both jets which will cause a build up of pressure & watch your cleaner to see if it climbs the walls like it should....of course if one or both you eyeballs are missing then there you go. Fixed my neighbors. It only cost him a case of Bud for my fix but he had already rebuilt both pumps & bought 3 different polaris's before I pointed out he had no eyeballs.
Posted on Jul 20, 2010
  • 366 Answers
Sounds like your impeller is clogged, you might be able to remove the pump basket and feel inside the impeller to see it it's impacted with debris. You may have to pull apart the pump to clean it thoroughly.
Posted on Jul 11, 2010
  • 1 more comment
  • Dale Cobb Jul 11, 2010
    if the impeller is clear, the problem may be with the motor sizing. Make sure the motor is rated big enough for the impeller. You can always but a bigger size motor on a smaller impeller but you can never install a smaller motor than the impeller is rated for. you will usually overheat the motor and it will cycle on and off with the high limit. Are you certain that there is not an obstruction in the suction line?
  • Dale Cobb Jul 13, 2010
    Suction side air leaks are a little hard to find. Check all of the most suspect items such as any unions (snug and O-ring intact), fittings (cracks or discoloration), and pipes and valves for obvious cracks. If you have a jandy type valve, check all the o-rings and lube everything. Make sure the threaded fitting going into the pump is tight. They can loosen if the pump has ever run dry or the wrong sealant was used.
    Sometimes you can turn the pump off and open the air relief on the filter to backflow some water through the suction line and hopefully you will see some water spurt out. It's difficult because water may not pass through spaces will air will. The last resort will be to have the entire line pressure tested. You may need to get creative.
  • Dale Cobb Jul 22, 2010
    I'm glad you found a solution. If you have plenty of flow and the cleaner is working well. You may try a new pressure gauge to double check it's accuracy. Thank you.
Pool heater
If you have bubbles, you have a suction leak. That means the pump is pulling air into the system. Sometimes it's just the basket o-ring under the pump lid needs replacing. If the pump has run hot (without water) for a while, it may have caused shrinkage at the inlet to the pump. Unless it is underground, suction leaks are fairly easy and inexpensive to fix. Heaters will not work properly with air in the system.
Jun 23, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I'm hearing air like sounds around the multiport valve. There's bubbles visible in the filter going to the pump. Bled the air on the filter itself and bubbles continues. Could the multi port...
Air only gets into the lines of your equipment if it enters somewhere on the suction side of the system. That means from the pump housing and strainer BACK to the pool on the inlets. Once the water passes from the impeller out the discharge of the pump it is under pressure and any leaks will result in water escaping from the line.
While your filter may or may not need work air is likely the result of failing gaskets or a seal in the pump. Replace the strainer lid ring, the pump body ring and the mechanical seal first. If there is still air look at the valve or valves in front of the pump for controlling inlet water flow...check for leaking stems or failing pipe joints.
John
Jul 21, 2011 | Pentair Kreepy Krauly Inground Automatic...
I have a Leisure Bay 24 ft above ground pool thathas a 1.5 hp Jacuzzi Hurricane pump and a jacuzzi sand filter. The pump is moving water very well but I noticed I have "a lot" off bubbles under...
probably a "O" ring as the seal
if the pump is doing what it is supposed to be doing and everything is normal. I would not stress about air under the cover as water contains air in suspension ( how fish get their oxygen to live) and from the turbulent action of the pump impeller , some of that air will be released and collected at the highest point of the flow line
Mar 28, 2017 | Jacuzzi Cyget In Ground Pool Pumps
I have a Whiperflo 3hp pool pump. The water
There are a couple things that you will need to check when pool pumps start losing pressure. Air bubbles are definitely one step, but check these things as well. Check you impeller to see if there is a clog or obstruction. You pump strainer could also be clogged. It could be that your o-ring needs to be replaced also. Try these things, reprime the pump, and see if it maintains pressure.
Jul 19, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Are vacuuming the pool . My sand filter does not work right it has no pressure going out to the pool. a pool store said it might be air bound .bleed the air out same thing
Do you have problems priming the system? If so you may have a suction leak in the plumbing attached to the front of the pump or a bad 0-ring seal in a valve. Symptom would be that when you set up to vac. The pump would lose prime or move very little water. Also maybe a clogged pump impeller.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Water surging back to pool when shut off
sounds like you have air built up inside the filter when the pump shuts off. the most likely cause is a suction side air leak, bad lid o-ring or union o-ring or maybe even the threaded fitting going into the pump. When you turn the pump off, you may be able to see water squirting out wherever the leak is. Once you find/fix the suction side leak the filter should stay filled with water and not surge backwards when the pump turns off. Make sure you keep the filter clean as well.
Apr 22, 2010 | Hayward SAND FILTER, PRO SERIES
I can not get vacuum pressure on my Hayward Sand Filter. I am using the Aquabug auto vacuum(which I've used over the last three seasons). When I fill the hose and put it into the skimmer port, I lose...
The filter is most likely not the issue at all.
When you lose vacuum pressure and see bubbles the problem is usually air getting into the line killing the prime. The most common place that air gets into the line is from the strainer cover on the pump. The clear lid on the front of the pump has an o-ring that after 3 years is probably due for replacement.
With a bad o-ring it's easier for the pump to draw air through the lid then water through 20+ feet of vac hose. Replace the o-ring, make sure it is lubed well with a non petrol based grease.
The only other issue that may cause this is a cracked or seriously warped strainer lid, which should be easy to recognize once it is removed to replace the o-ring.
Once this is done you should be fine.
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
My pool pump pumps water, return is low pressure
fix any air leaks on suction side of pump. Check valve positions.
Clean filters...may need to replace cartridges in cartridge filter, or take out D.E. grid assembly and clean it on a D.E. filter, or change sand in a sand filter...
Mar 26, 2009 | Pool & Spa
Pool & Spa Logo
181 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
